Loud BANG from EVO today under full boost...
Old Mar 26, 2004 | 05:12 PM
GottaGoFaster's Avatar
When I was driving today, I mashed down the gas in 3rd gear. Under full boost going like 70mph, I heard this loug BANG come from the engine. I then lost all power to the car!!! I tried to start it and NOTHING!!! Luckily, I was able to drift to the side of the road.
Upon inspection, I blew off the flex hose at the location circled in the pic. What is that part called that the hose is going in to?
Is there any damage that might have occured as a result of that happening?? I reset my ECU, reclamped the hose and it now seems fine
Attached Thumbnails Loud BANG from EVO today under full boost...-mrmotor1.jpg
Old Mar 26, 2004 | 05:14 PM
mhgsx's Avatar
It's called the throttle body.
Shouldn't have caused any damage unless something went in.
Old Mar 26, 2004 | 05:16 PM
DA-4BANGA's Avatar
Wow, relax dude, u just blew off the intercooler hose off the throttle body, happens a lot more often than u might think. It was probably loose, no need to worry........pretty scary feeling though huh?
Old Mar 26, 2004 | 05:21 PM
Ultor's Avatar
Jesus! that's happening a lot recently.
2 Dcevoclub members had them blow off on the same day, like 2 days ago.
Is it because it's getting warmer or something?
Old Mar 26, 2004 | 05:23 PM
Deceit's Avatar
Blown hose, pick up some new heavy duty t-bolt clamps
Old Mar 26, 2004 | 05:27 PM
LOL hell yea it was scary...Thought I blew the engine Nothing like blasting down the road then all of a sudden having no power to your car!!!
Old Mar 26, 2004 | 05:58 PM
GPTourer's Avatar
You also hit fuel cut. The ECU thinks things are rapdily out of control and yanks the timing.
Old Mar 26, 2004 | 06:08 PM
mitsuorder's Avatar
Yeah I second the t-bolt clamp option. Had mine blow off at the exact same spot after messing around with the car last weekend, truly a ball shrinking experience. Just if you get the t-bolt clamps pick up a deep socket 11mm or appropriate sized socket, if you use a shallow socket the bolt from the t-bolt will get stuck in it and it's a pain in the ***.
Old Mar 26, 2004 | 06:34 PM
I just finished cleaning my pants
Old Mar 26, 2004 | 07:30 PM
MrBonus's Avatar
I blew the one flex hose off that is coming up from the intercooler twice on the dyno. It's nothing a nice, tight T-Bolt clamp won't fix.
Old Mar 26, 2004 | 08:02 PM
Chris in HB's Avatar
*cough* hardpipe with silicone connectors *cough*
Old Mar 26, 2004 | 08:15 PM
UFO's Avatar
UFO
That loud bang and loss of power is the reason I now carry a 10mm socket & ratchet in the car with me (screw driver doesn't get it tight enough). After all, I think you can tighten/remove anything on this car with a 10mm anyway .
Old Mar 26, 2004 | 09:41 PM
Yea, I carry a socket set as well. I'm glad I didn't blow the engine...I wasn't carrying a spare one of those in the car
Old Apr 6, 2004 | 04:41 PM
Kyperion's Avatar
I had this happen today and I have not been able to reset my ECU yet, as i just got home. After tightening down the clamp and re-connecting things. I am now topping out at 17PSI of boost (on boost gauge), and then tapering down to 14. Is this something that the ECU reset will bring back up to the consistant 19PSI peak I had before this happened. Makes me worry that I might have hurt something in the Blow off valve or wastegate that is now costing me PSI on the top end.
Old Apr 6, 2004 | 05:08 PM
jemm's Avatar
Yep... a 10mm wrench should always be with ya.
these reversible Crescents are so darned cool :
