Evo 9 not boosting
Old Mar 17, 2016 | 07:35 PM
rabb77's Avatar
Evo 9 not boosting
Ok, I bought my car a couple of weeks ago, and not I am diving into the engine to see why it's not boosting past 10psi.
I have found a couple of possible issues, and need help learning what I'm looking at.
first pic is of a valve, I am not sure what it's for, but appears to be missing a vacuum line.
Second is the BOV, looks to be in poor shape and keeps venting at idle, and the nipple for the vacuum line is loose and I can't seem to tighten it.
that's all I have for now, I will work on it more this weekend.
Thanks for any advise in advance.
Old Mar 17, 2016 | 07:37 PM
rabb77's Avatar
Actually in the second pic, what is the vacuum line doing? it doesn't seem to be doing anything.
So any recommendations for a new BOV?
Old Mar 18, 2016 | 06:39 AM
egis's Avatar
I see you still on maf. Get used stock bov from a friend and see if it helps .
Old Mar 18, 2016 | 06:48 AM
Merle's Avatar
agreed stock IX BPV and a boost leak check
Old Mar 18, 2016 | 10:21 AM
rabb77's Avatar
Thanks I will get that checked out, but what about the BCS? and the missing vacuum line? or is that normal?
Old Mar 18, 2016 | 12:32 PM
egis's Avatar
Missing vacuum line needs to go to intake manifold and what's BCS?
Old Mar 18, 2016 | 05:46 PM
rabb77's Avatar
Originally Posted by egis
what's BCS?
I think it's the boost control solenoid, the small part missing a vacuum line.
time to find a vacuum diagram, or repair manual with the diagrams.
Old Mar 24, 2016 | 07:15 PM
rabb77's Avatar
Ok the old BOV was the issue! it was a not a recirculating type, and it was in awefull shape looking inside and inspecting it was far from in good working shape.
So I replaced it with the TurboSmart Kompact 34mm recirculating bov. well it now has full boost, and holding an idle and runs a lot smoother!
Old Mar 24, 2016 | 07:19 PM
roni4g63's Avatar
yeah unless you are tuned on speed density, you have to recirculate the air.
thee stig
North Texas Evo Club (NTEC)
Jul 13, 2023 07:38 PM
SilvrEvoIX
Oct 14, 2007 05:07 PM
03evo4g63
Jun 18, 2007 06:44 AM
Boostoff
16
Apr 2, 2007 03:08 AM
EVO8GSR
11
Mar 9, 2006 09:18 PM
