Erratic RPM problem,need help! with video!
Old Mar 21, 2016 | 12:26 PM
babaz7's Avatar
I didnt have any luck in the general forum, hope this one will have some luck.
i have a erratic rpm problem, it is not stable at idle. It goes up and down between 2000-2500 rpm's.
it was fine before, but then due to some problem with the car, it was grounded for over 3 months, after that i took it out for tuning and when i went WOT, this started to happen, or it is because i took off my electronic boost controller off because of it not working and i deleted the vacume line which goes into the EBC.
now what can cause it to idle like this? i have a video too, please watch it.
Old Mar 21, 2016 | 06:27 PM
Denzi_92's Avatar
Have you done a boost leak? Any My first thought would be High pressure at wot could have cause a coupler to come off/boost leak somewhere.
also try
Clean MAF
Clean IACV and check function.
Check TB for carbon buildup and function.
Old Mar 21, 2016 | 09:33 PM
babaz7's Avatar
also try
Clean MAF
yes i did a boostleak test. found small leaks and fixed them but still problem remains.
i will do the things you mentioned today, thanks.
Old Mar 22, 2016 | 07:01 AM
llDemonll's Avatar
check your IACV
Old Mar 24, 2016 | 02:09 AM
babaz7's Avatar
thankyou all for your help!
it was a bad IACV and i replaced it with another one now its working like new!
babaz7
Mar 24, 2016 12:28 PM
evo707
Jan 25, 2012 10:52 PM
Chamama
16
Dec 17, 2009 10:24 PM
