Driving to tuner w/ out tune. FP Red....
Changing a turbo is a huge change in airflow, just like cams. SD will not run well, if its even drivable, without changes to the ROM. I know this because I've done it, my car barely ran when I went form the stock turbo to the red. Required changes to injector scaling and RPM VE, as well as portions of the fuel table to even be able drive it somewhat reasonably.
On MAF he'll be fine.
If all you changed is a turbo you wouldn't need to touch injector scaling unless either the injectors weren't properly scaled or new injectors were added. Also the change in airflow when you change a turbo only happens when the turbo hits a higher boost level than the smaller turbo could ever have achieved at the same rpm. Like the poster above says, out of boost this is a moot point.
OT, OP stay out of boost and you'll be fine.
And yes, you can adjust injector scaling. That way you don't have to adjust the RPM/VE table around as much. It's speed density, you can do anything you want to adjust fueling. It's big picture thing since the ECU doesn't know how much air is going through the motor other than what you tell it. So you can tell the ECU their is more air by adjusting RPM/VE so you get more fuel, or you can tell the ECU the injectors are smaller so that you get more fuel since you have the same injectors.
Wicked_X
Jun 18, 2018 11:09 AM
BlckEvo8
Oct 9, 2007 08:11 PM
Evasive EVO
Evo 'For Sale' Wheels / Tires
46
Oct 11, 2006 02:24 PM
Robdevo
Feb 26, 2005 07:13 AM
