Engine afr
Old May 31, 2016 | 01:13 PM
EvO_essence's Avatar
Its definitely probably reading a tad leaner than it is, but when going to take off from idling you can tell its not getting enough fuel i think. how do you read the narrowband
Old May 31, 2016 | 01:15 PM
LetsGetThisDone's Avatar
Resolve the first KNOWN issue by putting the O2 sensor in front of the cat, where it belongs. Then you can worry about other possible issues.
Old May 31, 2016 | 03:20 PM
Bhsj13's Avatar
wait a minute, have you even got a base tune for it? you haven't mentioned anything about it since it is a fresh build. usually people get a break-in tune so you can drive it around safely. maybe you could start with having the shop do a tune for your break in period.
Old May 31, 2016 | 06:20 PM
Ive got a major exhaust leak i have found, also i tried unplugging the MAF and it seemed to even out very quickly.
Old Jun 1, 2016 | 05:32 AM
02modlanceroz's Avatar
Originally Posted by kikiturbo
boost leak will give you rich AFR not lean..
you either are measuring it wrong, or have a really lean mixture.. need to double check
It will make you lean in vacuum and rich in boost
Old Jun 1, 2016 | 03:38 PM
Bhsj13's Avatar
do you have a base tune for your new set-up?
Old Jun 2, 2016 | 02:03 PM
I do not.
Old Jun 2, 2016 | 03:54 PM
Bhsj13's Avatar
Originally Posted by EvO_essence
I do not.
This is your issue then my friend. get a base tune so you can drive and break in your new set up properly.
xPRimNT
157
Dec 26, 2018 08:09 AM
Clipse3GT
40
Oct 17, 2009 08:26 AM
Appauldd
Mar 24, 2009 10:29 PM
PlanoEvo
Oct 3, 2007 08:30 PM
nj1266
Mar 5, 2007 07:52 PM
