Evo 9 leak head gasket
Old Jun 10, 2016 | 09:14 AM
kajoo's Avatar
Hi
Evo 9, 2.3L engine, compresion 9.5:1, gtx3076.63, 490whp at 1.5bar
Head gasket is with metal rings and I have small leak on one of the cilinders between gasket and block.
What could be the reason?
Regards
Dimitar
Old Jun 10, 2016 | 09:26 AM
LetsGetThisDone's Avatar
The reason is the HG is blown. Time for a new one. While its apart, check the head and block surfaces for flatness, corrosion, pitting, etc..
Old Jun 10, 2016 | 09:47 AM
kajoo's Avatar
Is third gasket. And everytime we inspect/machine work head and block. Fuel is pump gas.
Old Jun 10, 2016 | 11:11 AM
Abacus's Avatar
Are coolant temps reasonable?
Have the injectors checked for flow.
Verify AFR is 11.0-11.5ish
Is it an atp kit or does it have a real exhaust housing
Use skinny fingers to tune it softer.
Old Jun 15, 2016 | 02:59 PM
Pal215's Avatar
Which head studs are you using ? Are you using the correct torque down pattern and a quality torque wrench? I wipe the head and block mating surfaces down with brake cleaner before installing the head gasket to make sure both parts are very clean.
-pal215
RedLanEVO
May 7, 2014 11:36 AM
javicracer
60
Aug 27, 2011 12:30 PM
Boost3dxEvO
13
Oct 2, 2008 12:52 PM
App420
Jan 27, 2007 11:02 PM
