No fuel pressure
Old Jun 19, 2016 | 06:36 PM
STIU2SLO's Avatar
No fuel pressure
Hey everyone got a 03 evo I just did a built motor trans tcase and fp black, I'm running a single re wired walbro 450, FIC 2150's and a fuel lab fpr, I was running this set up of fuel last year but with low z 1050cc I went to the high z 2150cc with p&p adaptors, I went to start the car first time this year and my fuel pump is not priming and injectors are not firing. If I jump the relay at the pump it will Build 44.5 psi but injectors will not fire I threw a P0201-P0204 code... Over winter My buddy deleted the resister pack and those relays on the fire wall... I feel like that is causing my problem, but I've read if you run high z you delete the resister pack anyways, anyone have an idea on what I can do? Also does anyone know what power I should have at the injectors and if they are a constant power source with a switching ground that maybe isn't making contact and I could just wire a constant ground to each individual injector or should I just buy a whole new main and engine harness and cut my loss...
Thanks for the help
Old Jun 19, 2016 | 07:16 PM
Bhsj13's Avatar
http://www.spoolinup.com/Injector-Re...pass_p_73.html
did you ever look into this made by spoolinup? but im no tuner so maybe someone with this se up can shine on this.
Old Jun 19, 2016 | 07:40 PM
STIU2SLO's Avatar
The wires from the harness are cut there is no pig tail left. So that won't work unless some how I can find those 3 black wires and the one white one... Which I just tried but didn't work still no fuel pressure idek if it was the right 3 wires
06EvoIXmr07
Jun 20, 2016 08:01 PM
colo_evo
Dec 30, 2007 08:20 PM
EVO MR FU
Nov 15, 2005 05:09 PM
jbigelow
14
May 3, 2005 08:46 AM
edtxag
Jul 31, 2004 09:14 PM
