Oil to BB turbo
Old Jun 20, 2016 | 12:05 PM
EvO_essence's Avatar
Oil to BB turbo
I am trying to run the oil feed to my turbo and the stock feed from the head became stripped and is now plugged off. Is there other spots on the head to pull oil from? I see a couple plugs on the drivers side, is one of them an oil feed plug?
Old Jun 20, 2016 | 12:31 PM
LetsGetThisDone's Avatar
Only the OEM port should be used. Otherwise you need to use the oil filter housing.
Old Jun 20, 2016 | 12:32 PM
What is the problem with the other head ports?
Old Jun 20, 2016 | 12:38 PM
Are you talking about the little allen plugs at the end of the head (cam sensor side)? I think they'll be too small. And they may not be accessible once everything else is installed. I had to find pics of bear heads to see them..
Old Jun 20, 2016 | 12:39 PM
let me send you a pic
And my engine bay is very empty so its ok. From what i was told even with a restrictor, it is too much oil from OFH for a dual BB
Old Jun 20, 2016 | 12:41 PM
Old Jun 20, 2016 | 12:42 PM
its the one on the right with the plug out that i am looking at
Old Jun 20, 2016 | 01:25 PM
anyone?
Old Jun 20, 2016 | 01:38 PM
You could try it. As long as its oil, I'm pretty sure that just the galley for the cam journals, which is the same as the turbo feed port.
Old Jun 20, 2016 | 02:04 PM
i think it is oil
I was hoping someone could verify this
Old Jun 20, 2016 | 03:04 PM
you could cover it with a rag and crank the motor, See what comes out. Usually when you pull plugs like that, if they're coolant plugs, coolant will come out..
Old Jun 20, 2016 | 09:44 PM
kikiturbo's Avatar
I will use that gallery plug, on the same oil gallery that is used by the OE oil line... it is right under the exhaust cam sensor.
Old Jun 21, 2016 | 05:09 AM
And that is defintely an oil port?
ive got an Kiggly HLA so oil pressure from the head doesnt scare me
Old Jun 21, 2016 | 11:47 PM
kikiturbo's Avatar
turbo oil feed is not regulated by the head regulator..
javicracer
Dec 13, 2013 01:16 AM
Anarchy99
Apr 30, 2013 08:00 AM
mrcox
Apr 14, 2007 09:35 AM
evoturbo131
Aug 7, 2003 03:33 PM
