EVO IX- engine runs a bit rough
Old Sep 24, 2016 | 05:51 AM
DONNOD's Avatar
Hi folks,
Car runs a bit rough every now and then (not always though,most noticed on cold mornings), feels like engine is not coming into boost and losing power. I also get hesitation on high boost with half throttle (24psi). I have replaced the plugs (NGK ILFR7H), fuel pump (Walbro 255), MAF sensor, getting new NGK ignition coils and leads also front O2 sensor.... I was wondering if this could be a boost or vacuum leak or air temperature sensor??? But it's weird as the problem doesn't occur always! Dyno test was done and the power was dropped by 20kw@wheels compared to 5yrs ago when it tuned. I like to hear some expert advice. Thanks
Old Sep 24, 2016 | 03:52 PM
Bhsj13's Avatar
maybe do a compression check. how about the turbo wg actuator?
Old Sep 24, 2016 | 05:52 PM
DONNOD's Avatar
Compression test was done and they all seems to be healthy. Engine had no sign or missing or detonation on Dyno test. I was told, drop in power is normal it could be related to many parts especially the aging spark plugs, so I replaced all plugs with Brisk, engine ran fine for a couple of days after I started to get misfire #4 error code so re-gapped the plugs but the problem returned. So, I replaced Brisk with OEM NGK plugs and that fixed the problem.
if the turbo wg actuator ceased or stuck, shouldn't it be a problem that occurs every time I drive?
Old Sep 28, 2016 | 06:32 PM
JKX's Avatar
JKX
Boost leak?
AustinB768
43
Jun 8, 2012 05:24 AM
Jersey Dino
Oct 29, 2011 10:22 AM
whitedemon
Jun 4, 2011 12:29 PM
widge
Nov 21, 2010 04:49 PM
binh
Sep 3, 2007 07:18 AM
