Exedy Twin Disc issue
Old Oct 5, 2016 | 08:21 AM
Kris86's Avatar
Hey guys, so I thought id see if any of you guys have ever had this issue before.
its very hard for me to explain really, but ill try my best
has anyone ever had a issue with this clutch where at times, for me, I would have different clutch engagement points, I think its mostly noticeable when its hot.
pedal has been adjusted and I have in a pull / push system already, so no slave cylinder.
one moment the clutch engages at the top of the pedal travel, e.x just before you take your foot off the pedal, then another time, id have the clutch pedal pressed to the floor and as I am engaging the clutch, half way up it starts engaging (clutch starts to bit near middle when pedal is travelling back upwards to engage clutch, which is a lot earlier than original) then the car will start rolling and then you will feel the clutch suddenly disengage, car stops its rolling momentum, and then it would reengage as I get to the top of the pedal travel where it is expected to engage.
hard to explain but I hope u guys can understand what im trying to say
Old Oct 5, 2016 | 08:27 AM
LetsGetThisDone's Avatar
Need to polish the towers of the basket. Mine did that. Took it back out, polished the towers, and it went away. I know what you mean though. It will randomnly have a soft engagement point that is much lower in the pedal travel than the actual hard engagement point.
Old Oct 5, 2016 | 08:32 AM
Kris86's Avatar
thanks alot for your help!
will driving it around like this for now do any damage you think? I plan to be tuning my car next week, was wondering if I can do that after it is tuned
Old Oct 5, 2016 | 08:35 AM
It'll be fine. Just make sure its not causing the trans to be difficult to shift. If it starts doing that you can hurt the synchro's.
Old Oct 5, 2016 | 10:31 AM
Kris86's Avatar
thanks man, appreciate the help
quite relieved that you couldn't understand whats happening.
prilianad12
Dec 30, 2013 04:42 AM
bruce988jl
11
May 8, 2013 01:23 PM
subrwho
23
Jun 25, 2010 03:38 AM
Evokid03
Sep 22, 2009 02:19 PM
