Fp red Boost Leak tester
Old Oct 21, 2016 | 10:07 AM
4b11slayer's Avatar
Whats up yall. Has anyone made or have a boost leak tester for a fp red?
Old Oct 21, 2016 | 10:19 AM
LetsGetThisDone's Avatar
You just need the right size reducer coupler.
Old Oct 21, 2016 | 10:24 AM
4b11slayer's Avatar
I think I over payed but just ordered a kit from boostleaktesters.com
Seems legit with 60 psi guage and everything.
http://turboboostleaktesters.com/evo...ite-3-25-84mm/
Old Oct 21, 2016 | 10:28 AM
That's actually cheap...lol. I bought the STM one a while back, its more than that and no gauge.
Old Oct 21, 2016 | 10:38 AM
4b11slayer's Avatar
Damn really? This was 60 with priority shipping.
Im hoping to find a boost leak on my car.
This tuning is getting frustrating.
Afrs are all over the place.
Old Oct 21, 2016 | 11:14 AM
heel2toe's Avatar
The idea is to perform a BLT prior to tuning But hey better late than never...
And geese that is friggin expensive. You can make one for like $10. all you need is a coupler PVC cap couple clamps and a valve stem. I dont have a gauge on mine but I use my tire filler so that has a gauge on it already so no need.
Old Oct 21, 2016 | 11:31 AM
4b11slayer's Avatar
Ive made one before for my evo 3 16g talon. Never got it right always leaking at tool.
Lol ill just add it to my tool box.
Yes I know it should have been done prior to tuning but.......
Old Oct 21, 2016 | 11:32 AM
I got tired of the PVC stuff not staying together so I bought the one STM makes.
Old Oct 21, 2016 | 12:14 PM
heel2toe's Avatar
Just gotta tighten the clamps more. Or get a bigger hammer!
And cmon Sean what a newb I thought you were legit...you can fab custom parts but can't make a boost leak tester. Im appalled no #evomguru for you!
Old Oct 21, 2016 | 12:50 PM
I was having a lazy day, and was ordering other things from them at the same time...meh lol
Old Oct 21, 2016 | 01:10 PM
4b11slayer's Avatar
Currently doing injector tuning.
Fic 1450 cc blue max on e-85
I used applaud user latency settings and brought me to -3 short fuel trim and -8 mid long trim.
1329 scaling is what I left and applaud and other suggest 1008 for scaling.
Will every set up vary some in scaling?
Do I lean out globally to correct the trims or maf scaling?
Old Oct 21, 2016 | 02:08 PM
heel2toe's Avatar
Every setup is going to be slightly different. Your injectors probably came with a card to get you in the ballpark and I know there is some good threads on here as well which sounds like you found.
Ideally you want to see your fuel trims within 5% so thats your goal. Dont start leaning out the maps or playing with MAF scaling until you have the injectors scaled properly.
But as I mentioned before you start playing around with the tune you must make sure your car is mechanically sound. If you have a leak what good is dialing in the tune around that? The second you fix the leak the tune is going to get effed up again.
Old Oct 21, 2016 | 02:42 PM
MAF scaling is part of getting the fuel trims dialed in, unless the MAF scaling was previously correct for whatever intake is being run.
Old Oct 21, 2016 | 05:08 PM
4b11slayer's Avatar
The car was previously tuned.
maf scaling is stock I think. Compared to my buddys car with non fp red same scalings on maf.
So lets say my fuel trims don't get any better then -3 with injector scaling adjustments.
Move on to maf to bring them in closer?
Old Oct 21, 2016 | 05:11 PM
4b11slayer's Avatar
Gotcha
I don't have the fic info card but the car was tuned before like I said.
It was tuned perfect but after walbro 450 install entire map is rich. So I checked fuel trims and were off so started messing with injector latencies. Car runs smooth with APPLAUD's Latencies. But my fuel trims are not having it.
