Evo 8 fresh motor only getting 2-4psi oil pressure
Old Dec 6, 2016, 05:32 PM
Ef8b16's Avatar
Sounds like you need to take her apart.
Great.... that's something I didn't want to do.
Old Dec 6, 2016, 05:34 PM
Ef8b16's Avatar
Since the oil pump has to come off is it better to run balance shafts or take em off on a daily driver?
Old Dec 6, 2016, 05:42 PM
LetsGetThisDone's Avatar
Received 1,547 Likes on 1,326 Posts
It's up to you, but I would keep them on a daily. Stay on top of changing the belt. Even double check balance shaft belt tension at 30k.
Old Dec 17, 2016, 08:36 PM
Ef8b16's Avatar
Will do
Old Dec 17, 2016, 08:37 PM
Ef8b16's Avatar
What are you guys using to delete oil jets?
Old Dec 17, 2016, 11:36 PM
kaj
kaj's Avatar
Why would you do that?
Old Dec 18, 2016, 09:42 AM
You don't delete the oil jets.
Old Dec 19, 2016, 08:45 AM
Ef8b16's Avatar
To get more oil pressure
Old Dec 19, 2016, 08:48 AM
Ef8b16's Avatar
I read that if your running aftermarket forged pistons there's no need for the oil jets.
Old Dec 19, 2016, 09:04 AM
barneyb's Avatar
Look at the clearances in the bearings and in the oil pump. A bandaid fix is not the right way to go.
Old Dec 19, 2016, 09:48 AM
Your issue is not due to oil jets. You need to find the actual issue.
You either have an issue with your oil pump/pick up. Or you did the balance shaft delete without rolling the bearing. It's not likely, but you could have WAY to much side clearance on the rods. Although, I don't think that would cause this drastic of an issue.
That is bad internet advice. If people think there is no need to cool the piston in a forced induction engine, let them deal with that.
Old Dec 19, 2016, 11:19 AM
meckert's Avatar
No body has asked what weight oil your using? If you are looking to bump pressure to a degree without taking things apart or deleting them---although you should find the problem first-- put in the Kiggly restrictor in the head. its a bolt up and even hot I am at 22lbs at idle @ 850rpm. Which is more that stock. Stock I was at 7-10lbs hot at same idle, I assume you were as well when the motor was running... I am not etirley sure you have a problem at 13lbs
Old Dec 19, 2016, 11:26 AM
I started the car today and is at 13psi at idle and at 1500rpm it drops to 12psi.
The issue is the oil pressure dropping when he goes from idle to 1500rpm. That should definitely not happen.
Old Dec 19, 2016, 12:54 PM
kaj
kaj's Avatar
No. Baaaaad idea.
Old Dec 19, 2016, 02:56 PM
Ef8b16's Avatar
Clearance is 00.15"
Quick Reply: Evo 8 fresh motor only getting 2-4psi oil pressure
