Please help!!! 05 evo
You probably have a lot of miles on the vehicle, so it would be pretty cost effective to refresh.
Light hone, remove glaze, install new rings from the dealer, re gap, you'll be ok the clearances are set so tight from mitsu, the pistons dipped to remove the carbon leftover.
Deck head and block, new headgasket, timing belt, balance shaft belt, or a delete your preference, tensioner, water pump.
Re use the stock valves, have them re seated, re use stock springs.
This is the cheaper alternative, VS 3 to 4 to 5 geez on a build,
Hope this lil insight helped.
nlp187
Jul 8, 2012 10:32 PM
DIDYSIS
May 9, 2009 04:30 PM
