transmission noise at idle
Old Dec 27, 2016 | 07:00 PM
nor11384's Avatar
FCOTM Winner
I have an evo 8 and at idle when the car is warmed up theres a loud rattle...i have tq solution mounts but when the car is cold it doesnt sound like this...i started doing some research and according to the tsb and jack trans everything leads to the reverse idler gear...the tsb says they sell a kit to fix this? anyone want to school me on this info? also, it says the reverse idler can be replaced without removing the trans? how do i access the reverse idler gear without pulling the tranny?if i dont replace it what happens? just have to deal with the noise?
*edit - forgot to say...if i press the clutch in and out a couple times i can get the noise to quiet down a bit some times...
Old Dec 27, 2016 | 07:03 PM
4b11slayer's Avatar
Does it go away with clutch in? Possible release bearing aka throw out
Old Dec 27, 2016 | 07:08 PM
kaj's Avatar
kaj
is it anything like this?
Old Dec 27, 2016 | 07:56 PM
nor11384's Avatar
FCOTM Winner
doesnt sound like that,..it sounds less steady any slightly deeper in tone...the noise goes away when i press the clutch and when the ac kicks on it seems to get louder...the car has tq solutions mounts and the clutch has maybe 4 - 5k miles on it...its an act clutch with oem tob...
*edit - forgot to say...if i press the clutch in and out a couple times i can get the noise to quiet down a bit some times...i just remembered this...thats pretty weird...
Old Dec 27, 2016 | 08:04 PM
kaj's Avatar
kaj
My problem was one of the alignment dowels was missing, so the clutch disc couldn't center. It cost me a transmission, but they time I figure it out. Keep an eye out for that, unless you know yours are both in place. If so, that eliminates one possible cause LOL.
Good luck, brotha!
Old Dec 27, 2016 | 08:08 PM
lonestarr20's Avatar
Throw out bearing, replace it
Old Dec 27, 2016 | 08:09 PM
nor11384's Avatar
FCOTM Winner
alignment dowels? you mean for the forks that change gear inside the tranny? the ones people safety wire? if so i took it apart once and put new pins in it and safety wired it but the problem was that 3rd and 4rd was is if youre in neutral...
Old Dec 27, 2016 | 08:10 PM
nor11384's Avatar
FCOTM Winner
thought about it but its been making this noise since i can remember and tob is oem and fairly new...if its tob then im riding this ***** till the wheels fall off...im not dropping tranny just for tob lol...
Old Dec 27, 2016 | 08:12 PM
4b11slayer's Avatar
I have a act hdss and its noisey as hell. Whines like a ***** during release at times.
Old Dec 27, 2016 | 08:42 PM
Till the wheels fall off
Old Dec 27, 2016 | 09:21 PM
nor11384's Avatar
FCOTM Winner
lol
Old Dec 28, 2016 | 12:20 AM
kaj's Avatar
kaj
No, the dowels between the trans case and block. One of mine had fallen out and I didn't notice. The trans was misaligned and killed my original 6spd. It was an expensive oversight on my part...I've never had one fall out before, so never thought to check. Oops.
Old Dec 28, 2016 | 11:21 AM
nor11384's Avatar
FCOTM Winner
wow thats crazy...well, mines were on when i installed the transmission...
Old Sep 13, 2019 | 07:57 PM
Randy Joshua's Avatar
https://youtu.be/Iti6tG4vzEs
Hey mine actually sounds almost exactly the same as in the video, I was thinking it was my transmission. Lmk if im wrong
Old Sep 14, 2019 | 07:47 AM
nor11384's Avatar
FCOTM Winner
Well my noise is still there. Like i said in 2016, ride it till the wheels fall off. I’m guessing it’s probably gear rattle. Sound is prob magnified since I have tq solution mounts.
