Best Rotating Assembly For FP Black/PT6262
When building, from experience, what is the best rotating assembly to go with on a VIII or IV? i've seen many but i want to know from experience. I willl be going with an FP Black or a PT6262. Car will be a daily and i dont plan on doing any autox, maybe a couple 1/4 miles passes but i just want a street monster. I plan on going E85 in the summer and 93 in the winter. Any fuel system that you guys recommend to use as "flex fuel" to where i can pump either or and choose the specific tune for it? I can keep my foot off of it but the main reason for building is because i want something that'll beat 90% of the cars in my city and to attend car meets and what not. I will not abuse it as much but i want to be able to get a little more hp in the near future. My main goal is 500AWHP-550AWHP.
On E85, your turbo selection is well above your power goals.
I would build a 2.0L, or a 2.2SLR (94mm crank, 153mm rods). A PT5858 or FP red will more better suit your power goals.
As long as you're building the motor right along with this turbo upgrade, I would do a gen 2 6062. Its capable of more power than the standard 6262, and will spool faster.
http://www.precisionturbo.net/Street...T6062-CEA®/582
Yeah I was taking the PT5858 under consideration but i want to be able to add more in the future so i rather have the 6262 or the FP Black and push not much boost to begin with then just turn it up whenever i get tired of the 500-500 to the wheel. Another reason in waned to start small was because i will be upgrading everything else as time goes on. That way i wouldn't have to go back and buy a bigger turbo when everything was said and done.
norcalSRTrida
16
Jan 2, 2009 10:37 AM
Evo_SpeedKing
92
May 28, 2008 08:48 AM
RalliartMR
Jan 14, 2008 07:57 AM
Evo_SpeedKing
57
Nov 19, 2007 09:35 PM
hotrod2448
21
Nov 15, 2006 07:17 AM
