Exedy Twin VS ACT
Old Mar 14, 2017 | 06:54 PM
Bhsj13's Avatar
Originally Posted by maxroach
I am on my 30k miles on ACT HDSS too.
Question:
How do I know or symptoms of ACT about to go already?
I mean, still grabbing good now, no issues for the 30k miles already.
im asking coz im about to get a new tune for new turbo set up
(stock turbo to green), do I need to replace the clutch, eventhough still
grabbing good?
you dont need to replace unless it is slipping.
Old Mar 15, 2017 | 02:41 PM
LetsGetThisDone's Avatar
You can tell there bad when the engagement is really high, no matter how you adjust it, and the gear box will sometimes get notchy.
Old Mar 15, 2017 | 04:59 PM
Bhsj13's Avatar
^^ yeah, mine isnt slipping yet (at WOTs) but it grabs pretty high. but not needed to change until it starts to slip.
Old Mar 16, 2017 | 07:57 AM
CaptainSquirts's Avatar
My first one that lasted 65k miles was a 6 puck. It was grabbing fine but would sometimes have some clutch chatter if I didn't take off correctly. But at that point the clutch wore down to the rivets and my TOB went bad before the clutch actually started to slip. So I def could've gotten more miles from it(not sure how bad it is to use a clutch when it's worn to the rivets) if my tob didn't fall apart.
Old Mar 26, 2017 | 01:59 AM
4g63Moon's Avatar
For daily driving the ACT will do perfectly fine but when racing and banging through gears and in the long run the Exedy Twin is the way to go.
Old Apr 23, 2020 | 03:44 AM
basswerks's Avatar
thanks fellas this made a interesting read. In 2020, are the views about these clutches the same?
Old Nov 17, 2020 | 10:11 PM
Lancer_Evo_8's Avatar
Is the Flywheel at the exedy twin lighter than the stock Flywheel?
Old Nov 18, 2020 | 06:40 AM
bboypuertoroc's Avatar
Veteran: Army
Exedy twin flywheel is 11.8lbs. OEM is 13.9lbs.
After running an ACT and Exedy twin I would take the twin no question. The ACT did last forever but the high RPM lockout was insanely annoying. Never had any issues with the twin and I've had no issues now with my triple (I actually like the triple better than the twin).
Old Nov 18, 2020 | 07:23 AM
blackline's Avatar
5 Year Member
ACT now has a the twin disc for Evo 8/9(released 11/17/2020).
Part number for act twin that is rated for 800tq(crank) T2S-M01
Tommyy
Jan 12, 2017 12:47 PM
Grimgrak
Jul 18, 2013 02:30 PM
RaysEvoX
14
Mar 31, 2011 10:38 AM
njvlllrs
12
Jun 14, 2009 11:34 AM
LI Pinky
26
Dec 10, 2008 11:11 AM
