Oil Return Line Question
Old Mar 9, 2017 | 08:26 AM
Verlassene's Avatar
Ok so quick question for y'all, can I use a braided oil return line like this STM one on my stock Evo 9 turbo to my stock Evo 8 oil pan like I'm getting the impression?
https://www.maperformance.com/products/stm-turbo-oil-return-line-10an-2003-2006-mitsubishi-lancer-evolution-8-9-evo89-torlb-stk
I believe I have a crack in my oem and have had repeated leak issues from its gasket/flange on pan side before so I would like a better solution than another oem to give me hell lol
Old Mar 9, 2017 | 08:45 AM
LetsGetThisDone's Avatar
The OEM works fine as long as you use a NEW OEM gasket, and the oring washers under the head of the bolt. I would pick up a new return tube/line, gaskets, and the oring washers for the bolt. The AN stuff is more hassle than its worth.
Old Mar 9, 2017 | 10:55 AM
Verlassene's Avatar
You really think so? I replaced the gaskets twice now believing that to have been the issue without success, now I'm almost sure the line is cracked from trying to get it flush and installed. I just had a conversation with a mechanic where he said he thinks the oil pan side has two different angles depending on build date and that I may have had the wrong return line ( I have two one from my car and one from the IX turbo but can't recall which I used..) and that I may have cracked the line flexing it to fit the angle
Old Mar 9, 2017 | 10:56 AM
Verlassene's Avatar
My thoughts on the AN line were that it would always be flush and present no cracking risk...
Old Mar 9, 2017 | 11:04 AM
The line can crack, but it's not common. If your car is an 8, you need to use the 8 return line.
EvODavO
Feb 28, 2016 04:12 PM
Enyth
28
Jul 14, 2014 01:52 AM
triple L
Feb 19, 2013 12:34 PM
MarksIX
For Sale - Part Outs
10
May 31, 2009 03:49 PM
OtownEvo
Sep 24, 2007 01:54 AM
