oil spark plug
Old Mar 15, 2017 | 07:13 PM
4G63_EVO's Avatar
Originally Posted by redman007
Thank you for your advice. Ok, today I spoke to the guy who sold me the car. I told him about the problems that I've been having. Maybe you all with more experience can tell me if this makes any sense. He said that what I explained to him has also happened to him in the past. The car is fully forged , 2.3 stroker kit,has bc272 cams, 560 cc injectors,Wabco fuel pump, eagle crank, fpr. He said the car is fuelled aggressively because of the set up and when started if over revved to prevent stalling its very easy to flood the engine. What I saw on the plugs would have been fuel mixed with carbon deposits which could look like oil. Does that sound like it could be a possibility ?
Ive only taken out the car once and didn't drive it for very long because of the problems I had and didn't want to make things worse. I will do a compression test this weekend and report the results.
Sounds kinda fishy to me, =1 on doing the compression test
Old Mar 16, 2017 | 05:19 AM
RightSaid fred's Avatar
Not even forged..............Just standard?
How would you know?
Well ummmm
If you can't even figure out what's wrong with it?
Old Mar 25, 2017 | 02:33 PM
redman007's Avatar
Ok so did the compression test and the figures
were
cylinder 1. 180
cylinder2. 170
cylinder 3. 175
cyoinder 4. 150
cylinder1 is the one that had the problem with the oil deposits.
As far as how the car drives , when the foul plug was cleaned the car flew and didn't miss a beat. Didn't drive it for very long though , only about 2 miles .
Any ideas? Is it likely the head of the block /pistons that's causing the problem ?
thanks guys
Old Mar 26, 2017 | 12:30 PM
Compression tests don't help.........as you now know.
Old Mar 27, 2017 | 10:03 PM
4b11slayer's Avatar
Picture of "oil"
Old Apr 2, 2017 | 01:29 PM
barneyb's Avatar
It sounds like the only thing this car needs is a decent tune.
Old Apr 3, 2017 | 09:34 AM
4b11slayer's Avatar
tube seals bro like I said
Magrud3r
Sep 25, 2014 06:22 PM
AWDBus
Dec 8, 2011 11:01 PM
fimotorsports
Nov 19, 2007 01:55 AM
QAT-R
Aug 31, 2006 11:05 PM
SlowCar
Dec 30, 2005 04:07 PM
