Weird Idle & Stall
Old Mar 17, 2017 | 04:58 PM
AKB_EVO's Avatar
Weird Idle & Stall
Hi,
So ive been having this issue for a while now- the car has a strong cold start but once up to operating temp and I shut it off- it has a weak and stumbly idle. This is only when re-starting when the engine is warm.
I found a small crack in one of the runners on my turbo manifold- but didnt think this would cause this issue. Its being replaced this week cause my AFR is jumpy due to this leak.
Also noticed when going into reverse the car wants to die at times, but not always.
Any help would be appreciated!
Thanks!
Old Mar 17, 2017 | 05:09 PM
maxroach's Avatar
There a lot of factors regarding cold start , wierd and fluctuations idle.
It could be vacuum leaks
Spark/ignition issues
Fuel pump or fuel issues ETc.
Try to remember what was the last youve done in your evo before
You have this issues and go from there.
Good luck..
Old Mar 17, 2017 | 05:17 PM
AKB_EVO's Avatar
I purchased the car a few months back. Sorry- shouldve included that.
I checked and no vacuum leaks. Could the cracked manifold cause this type of issue? I guess its considered a vacuum leak since its a leak before the turbo.
Appreciate the help! Thanks maxroach!
Old Mar 17, 2017 | 05:34 PM
maxroach's Avatar
Np
It could be the cracked mani..
Check also the following:
Your Fuel
Fuel Filter by the pump
Ignition coils and wires
Plugs
Old Mar 17, 2017 | 08:23 PM
deremer71's Avatar
I'd fix what you know is wrong and see if that fixes your problem. If not, start with cheapest possible fixes and gradually get to the more expensive/time consuming ones.
Old Mar 18, 2017 | 05:28 PM
AKB_EVO's Avatar
Thanks guys, Ill check it out. Once manifold is replaced and problem presists- ill try to narrow it down by checking fuel, fuel filter, and plugs & coils.
Old Mar 19, 2017 | 10:08 AM
deremer71's Avatar
Good luck. Report back once you find the problem or narrow it down a little more.
Browningmx98
Jun 7, 2015 05:51 PM
jwick76
Lancer Engine Management / Tuning Forums
Dec 12, 2012 09:54 AM
JKD
Aug 29, 2009 05:20 PM
VOLFLO
Mar 26, 2007 06:13 AM
visualkei72
Lancer Troubleshooting
18
Oct 22, 2002 12:07 AM
