Clutch problem?
Old Apr 7, 2017 | 11:25 PM
evo2pwr's Avatar
Clutch problem?
Hi there, i need a evo guru, i have a genuine evolution 2 and it started crunching gears the other day as i drove it, just made it to work, turned the car off and back on and now won't go into any gear? ANy help would be much appreciated..
Old Apr 8, 2017 | 12:56 AM
evo_flush's Avatar
Check the slave cylinder or master cylinder ! the slave cylinder could be broken too! If the line is broken there will be air in the slave cylinder so Check
For leaks and level on the brake reservoir . If everything looks fine then the clutch could be bad
Old Apr 8, 2017 | 01:49 AM
evo2pwr's Avatar
Thanks Evo Flush, everything looks fine via clutch and brake reservoir, just jumped in fired her up and is going through the gears like normal?! I'm stumped!!
Old Apr 8, 2017 | 08:12 AM
evo_flush's Avatar
Check ur shifter cables bushings or linkage
Good luck man ��
Tim2s3
Apr 24, 2009 05:14 AM
05EvoVIII
29
Apr 20, 2008 12:46 PM
ohthree
Jan 14, 2007 07:06 PM
Gruppe-S
Jan 12, 2007 04:11 PM
Go_Lancer_Go
Lancer Tranny/Drivetrain Tech
17
Jul 23, 2005 07:09 PM
