Getting locked out of all gears need help
hello,
so i first off i have a quartermaster 8 leg with hydraulic tob. it is not making noise. I did a few high rpm pulls with no problem(8500 rpm). everything worked great. I parked it came back 12 hours later to drive it at night and i am having severe clutch drag. I went to shift into first and the car instantly starts to pull forward while clutch is fully engaged and i am looked out of reverse for the most part. i though maybe master cylinder so i bought a new one bled it and still doing the same thing any advice?
hello,
so i bleed to cylinder again. i can see the tob engaging( i dont know if it is fully engaging) i can t tell if it leaking atm due to it having fluid from bleeding it poorly the firsttime
Kreeker
May 10, 2012 07:01 AM
