Help...gears locked out
Ok so this started like 3 days ago and is starting to get progressivly worse. When my car is off i can shift into each gear fine but once the car is on, it locks out the gears. It took me 3 minutes this morning to get it into reverse. Its like a brick wall. Could this be my clutch going or possibly something to do with the tranny fluid? I have an ACT street clutch with a Toda super light weight racing flywheel. They have a little over 10k miles on them I believe. Im just hoping it isnt my tranny. Does anyone have any ideas of what it could be?
also, try adjusting it. http://www.teamrip.com/clutch%20adjustment.html
Yea so my car is sadly going to have to be flat bedded to the shop tomorrow. So depressing. Now the gears are completely locked out. I put it into reverse and turned it on yesterday and it immediatly started moving. The clutch was to the floor but was acting like it was releasing. Almost like it doesnt even work. Does it sound like an adjustment problem or is my clutch completely shot?
did you adjust the pedal higher??? http://evomoto.com/tech_info.php?tec...0f0ddd87135840 read the tech tip of step #1
i had that problem with my rsx, and my problem was the pressure plate teeth is all messed up. don't try to get it in gear. u will grind ur gear and something will break. just take it to the shop.
Ill let you guys know what the problem is when its resolved.
