Evo 8 Buzz/rattle at 3500+ rpm?
Old Jun 25, 2017 | 12:50 PM
fuzzycuffs's Avatar
Question Evo 8 Buzz/rattle at 3500+ rpm?
Hey all. Noticed a buzz/rattle at 3500+ rpm in my 2003 Evo 8. Can really hear it while at the front of the car, and feel the resonance in the accelerator. Seems to be coming from behind the engine/under the car instead of around the timing area, or at the turbo -- but judging sound by position isn't the most accurate.
Looked under the car and checked things like heat shields and exhaust, all seem to be 'stable' for lack of a better term. I thought maybe a bolt was loose or something was touching something else.
Any ideas on what it could be or other things I could do to diagnose it? Here's a video of inside the car:
https://1drv.ms/v/s!AusKqMHhrFDYiNgb49hHz035_uAobg
Thanks!
Old Jun 30, 2017 | 11:19 AM
wingless's Avatar
Thanks!
as the driveline wears the shims, bearings and gears wear and develop lash that resonates through the cars, particularly on decel.
There is a million variables but in the end your going to do clutch TOB transfer case/front diff, transmission center/diff and possibly the rear diff before you can be 100% NVH free on a 2003.
Generally in that order, a worn twin plate clutch will do that all on its own.
Old Jun 30, 2017 | 12:18 PM
4b11slayer's Avatar
oh damn that sounds scary. Could be in the timing belt area. Use a piece of hose to pinpoint area. Use it like a stethoscope.
Old Jun 30, 2017 | 06:31 PM
barneyb's Avatar
I had the same thing and spent an evening listening and driving around trying to come to some conclusion. I even changed the accessory belt idler pulleys, good idea anyway, but to no avail. Somewhere along the line the noise went away, most likely something I did as part of maintenance or at least as part of taking things apart and putting them together again. As part of any Evo project there comes the morning spent hand fitting the plastic clippies trying to find the perfect one for each hole for a tight fit instead of the usual coming loose in a couple of days. I also still run the stock exhaust with slowly rusting off heat shields - another source of noise.
Old Jun 30, 2017 | 08:44 PM
Biggiesacks's Avatar
Double check the balance shaft belt
Old Jun 30, 2017 | 09:29 PM
barneyb's Avatar
SaulHudson
Nov 22, 2011 12:01 AM
RunRunRun
Nov 19, 2008 07:53 AM
rice_rocket88
Sep 24, 2006 11:45 AM
