ABS question
ABS question
Is there any way I can verify if my abs is working properly? Apart from the abs light?
few days ago i stomped on the brake n the car slid out of control.. luckily didnt hit anything..
Besides a mitsubishi scanner only way is what barney said. Slam on brakes try and lock up the tires. You should feel a pulse modulated vibrstion on pedal. And your tires should not screach well if they do its not a sliding screach its a screach pause screach. On and off
TariqEvo (Jul 23, 2017)
Forced me to slam the brakes, the tyres did screech, nor did the car slide on one side.
does that say that my abs works? or not sufficient to tell?
doncarbone
14
Jun 17, 2016 02:08 PM
FS[Northwest]: RS non abs/abs delete prop. valves bnib mr249607
420a-t
Dec 23, 2014 10:17 AM
