Valve cover baffles with a catch can
Old Aug 21, 2017 | 04:06 PM
moyassine's Avatar
How's it going. So today I decided to install my catch can. Took the valve cover out, drilled the baffle out. And it appears that the fitting for the catch can will hit a little bit on the baffle. Is it okay to trim it a little bit?
Attached Thumbnails Valve cover baffles with a catch can-received_993944737423929.jpeg
Old Aug 21, 2017 | 05:15 PM
hutch959's Avatar
im alittle confused.
if the baffle is out, why would it hit the baffle?
if you run the car with no baffles, it will pump a ton of oil
Old Aug 21, 2017 | 09:21 PM
Teal2nnr's Avatar
What do you need to trim? I have -10 fittings and didnt have to trim a thing.....
Old Aug 21, 2017 | 09:31 PM
moyassine's Avatar
I am running a -14 fittings. And when I install the baffles in. They will hit a little bit on the fitting end
Old Aug 22, 2017 | 10:13 AM
Teal2nnr's Avatar
Good lord, why? Pretty pointless. Go -10, you'll be fine. If you NEED -14 to sleep at night, then ya modification will be required.
Old Aug 22, 2017 | 10:19 AM
LetsGetThisDone's Avatar
No need to run -14.
Old Aug 22, 2017 | 12:47 PM
RazorLab's Avatar
-14? Is it hooked up to the New York sewage system?
420a-t
27
Aug 1, 2023 09:27 AM
vortico
Jun 21, 2017 11:38 PM
skatermsmn
22
Mar 28, 2013 03:24 PM
anthonyrb98
50
Sep 11, 2011 07:49 AM
