Apexi PowerFC MAP Sensor Problem
Old Aug 21, 2017 | 04:49 PM
TonkaTrain's Avatar
Hey everyone, I'm having a major issue with the evo I bought about 4 months ago. After sitting overnight the car refuses to start at all, it will crank fine for days fine but never actually fires.
This made me think it was possibly a sensor so i checked the output's in my power fc commander. Sure enough the PA value which is "atmospheric pressure sensor" in the manual was reading 0.00v while sitting or cranking. I assumed this was the MAP sensor, but the value above is BOST (External input pressure sensor) and it is reading voltage.
Here is a video of the sensor outputs while cranking:
Hoping someone could chime in if they know the difference between these two sensor outputs. Does it have more than one MAP sensor? Maybe the other is an output from the powerfc's boost controller?
I'm learning about this stuff fast, but my knowledge is pretty limited and I'd love some insight.
Thanks
Old Aug 21, 2017 | 10:01 PM
4b11slayer's Avatar
Even if it were a bad map sensor it still start up.
You should do the basics of a no start condition.
Spark
Fuel
Compression.
Code search
saad601
Mar 27, 2010 10:53 PM
evoseb08
Aug 25, 2009 06:16 PM
alex750803
Dec 23, 2008 05:38 AM
HiHeatEVO
For Sale - Part Outs
Aug 30, 2008 08:57 AM
TalonRcR
Jun 21, 2004 09:26 PM
