Are cam gears NEEDED when installing Gsc S1s?
Old Aug 22, 2017 | 08:19 PM
4G63_Crazy's Avatar
5 Year Member
Title says it all, any help would be great. Sorry about the noobness!
Old Aug 22, 2017 | 09:22 PM
maxroach's Avatar
No. Dont need.
But i have AEM Tru Cam set for Evo 8 for sale
If you running clear cam cover and want cool looking gears!
Old Aug 23, 2017 | 12:02 AM
RightSaid fred's Avatar
You won't know until you degree the cams.
They're all different by different amounts.
Old Aug 23, 2017 | 01:27 PM
LetsGetThisDone's Avatar
GSC is really good about machining the cams properly, no need for adjustable gears.
Old Aug 23, 2017 | 01:53 PM
Pal215's Avatar
As most people have mentioned, no need for aftermarket cam gears. I have heard of adjustable cam gears needed if the cylinder head or block deck has been resurfaced several times to the point where it starts to effect mechanical timing, but if it's a virgin block and head, there is really no need. Oems are the best option.
Old Aug 23, 2017 | 11:23 PM
Block surfacing only affects cam angles by a max of about 0.5 crank degrees.
It's easy to work out but people keep on repeating lots of crap.
There's always more error in reground cams.
Old Sep 3, 2017 | 11:43 AM
jonathanheierle's Avatar
dont need them unless you want your engine to look super sweet
Old Sep 6, 2017 | 07:43 AM
Really? My GSC's are dead on...
Old Sep 6, 2017 | 01:31 PM
It's not a case of being dead on(no cams ever are apart from factory ones), it's a case of measuring every one and making sure it's dead on and also being able to adjust it to however you want to.
The recommended settings are not always best.
Old Sep 6, 2017 | 03:23 PM
You just said no cams are ever dead on... I've installed more than a few set of Kelfords and GSC's and all were perfect.
Maybe if you're buying/using some junk cams like BC, or some other meh brand, sure. Otheriwse, adjustable gears are not needed. And changing time to change power curve is also an optional thing.
Old Sep 6, 2017 | 10:36 PM
Stevie Wonder's self fitted cams are perfect too.
Old Sep 7, 2017 | 10:00 AM
All you do is verify timing, it's not hard.
GSX_TO_EVO
Sep 5, 2016 07:49 AM
Colt4g63
35
Apr 28, 2008 11:55 AM
laramie_05MR
Apr 15, 2008 03:14 PM
joedr
Feb 11, 2008 08:27 AM
joedr
GSC Motorsports - Charleston, SC
Aug 21, 2007 05:27 AM
