Need help choosin the next mods for hp gains
Old Sep 4, 2017 | 01:33 PM
Evo8life's Avatar
Hello everyone i need litle help choosing the best next mods i need to yeld some significant hp gains on my 2003 evo 8
Current mods:
Buschur intercooler with upper and lower ic pipes
Borla 3" TBE
20g turbo with buschur ported 10.5hotside ,ported exhaust manifold,ported intake manifold,
Tial qr bov
Omni 4 bar map sensor
Perrin fuel rail
Fuel lab fuel pressure regulator
Boomba throttle body
Vibrant maf adapter+perrin intake
Hallman pro rx boost controller
Act single plate clutch with lightweight flywheel
Walbro 255 fuel pump
Anyhelp would be greatly appreciated
Old Sep 4, 2017 | 01:38 PM
Biggiesacks's Avatar
E85
Old Sep 4, 2017 | 02:07 PM
4b11slayer's Avatar
Cams.
E85
Beehive springs
Arp head studs to boost 30psi or more.
Old Sep 4, 2017 | 09:23 PM
Evo8life's Avatar
Sorry guys forgot to mention we dont have e85 in my country although wish we had but thats not poasible
Old Sep 5, 2017 | 08:41 AM
Evo8life's Avatar
My current turbo is a kinugawa 20g from ebay the turbo is running good at 23 psi 98 ron .will i see significant gains if switching to an hta73 green or any similar size turbo on pump gas
Old Sep 5, 2017 | 11:11 AM
2winscroll's Avatar
http://www.forcedperformance.net/PROD/NTEVOBLACK.html
Best deal for the $$$$$
Green won't get you much if anything compared to what you have.
Old Sep 5, 2017 | 01:12 PM
Boost Demon's Avatar
Veteran: Air Force
I would say, injectors, cams, or an FPGreen/Red/Black turbo. Maybe a coil on plug setup to smooth things out and add a little hp.
How long have you been running your 20g?
Old Sep 5, 2017 | 01:14 PM
Eric SlowEvo8's Avatar
Or fp red
Old Sep 5, 2017 | 09:47 PM
Evo8life's Avatar
Boost demom the 20g came on the car when i bought it so its been running good for a while it has an 8 compressor housing as i can see not a 9
Old Sep 10, 2017 | 12:26 PM
codgi's Avatar
budget and purpose for the car?
Old Sep 10, 2017 | 03:23 PM
Evo8life's Avatar
roll racing and highway pulls as for budget nothing too extreme not willing to build the block
Old Sep 11, 2017 | 10:04 AM
Evo8life's Avatar
it seems going with the fp red and gsc s1 or s2 cams + injectors is great setup on pump stock block for low 400-430 whp
Old Sep 12, 2017 | 03:00 AM
Veteran: Air Force
I've never run, or been in a car that had an FPBlack, but that may be the way to go for roll racing. I thought the boost threshold on the FPRed was perfect for the street and limited drag racing I did. I've seen that the MHI housing made it pretty close between the two, but someone else would have to chime in.
Old Sep 12, 2017 | 05:06 AM
my car came with an fp red at 564 hp and its fun I know it has more to it so once I make a few changes ill have my shop retune and see if we go 580-600 but knowing me it will come off for a 6466 like my old evo for 700+
Old Sep 12, 2017 | 06:25 AM
Evo8life's Avatar
<br />most of the roll races we do are from 2nd gear roll we dont have crazy fast cars here so running 450whp-500whp that would be considered a really fast car if you know what i mean for that i think the fp red would be enough or am i wrong?
