Head Gasket Help
Old Oct 3, 2017 | 04:54 PM
N3WBI3's Avatar
Originally Posted by Westfield93
they sell a head gasket tester... could start there. the fluids blue and if I turns yellow/green you've got exhaust fumes in your coolant system. you may want to mark a tooth on your gears then mark the belt as well with a paint pen. that way when you line it all back up it will only go one way. timing belts are made out to be a terribly hard task to endue. their not too bad. make sure you set your tensioner right and don't be cheap get a whole kit if your in there. replace it all!
The build only has 6k miles on it. Everything was replaced then so I'm good there. And I was planning on marking the belt and gears with an aligning mark too.
Ive seen said kits but this thing shoots water out of the fill hole with all of the force lol
Old Oct 3, 2017 | 06:32 PM
Westfield93's Avatar
Is it coming out of the radiator cap itself of the plastic "neck" of your radiator? If it's just shooting up out of one of those I'd start with replacing that. And if it's just the cap you can still use the head gasket tester. It replaces your radiator cap when your testing your head gasket. I'm gonna assume your overheating or running hot as well then too. Although if it's coming out of the radiator, that head gasket tester may not work, just an fyi if you decide to buy it and it "passes"
Old Oct 3, 2017 | 07:21 PM
barneyb's Avatar
Sounds to me like the gasket is blown. As for pulling the cams, you can try a shortcut. I don't like them. It always seems that something slips and then I'm reduced to doing it the FSM way. So, I suggest just figuring on that from the start.
Old Oct 4, 2017 | 12:25 PM
N3WBI3's Avatar
I get what you're saying. Ill try the shortcut with marking the belt location on its respective gears and go from there. Ill still align it at TDC before i start anything just in case.
What is the FSM way?
Old Oct 4, 2017 | 04:18 PM
barneyb's Avatar
That way.
Old Oct 4, 2017 | 06:20 PM
N3WBI3's Avatar
Oh lmao. I wouldnt do this if i was a business or on a customer car. But if i can be a little selfish and save myself a little time ill give it a shot.
Old Oct 31, 2017 | 11:48 AM
N3WBI3's Avatar
The carnage
Old Oct 31, 2017 | 01:20 PM
heel2toe's Avatar
Ouch head looks trashed bummer! Hows the surface on the block?
Old Nov 1, 2017 | 12:17 PM
N3WBI3's Avatar
Block surface looks OK thank god.
javicracer
60
Aug 27, 2011 12:30 PM
domantas
11
May 14, 2010 07:43 PM
Boost3dxEvO
13
Oct 2, 2008 12:52 PM
App420
Jan 27, 2007 11:02 PM
