Storing a built block
Old Oct 5, 2017 | 05:52 AM
blackline's Avatar
5 Year Member
I got a built block on my engine stand and the engine wrapped with shrink wrap until I get can complete my built. Is there a correct way to store the block for a long period? Should I lube the block every XX days?
Old Oct 5, 2017 | 07:59 AM
barneyb's Avatar
Drop it back in the car. With stock cams and a stock turbo it shouldn't even need a tune.
Old Oct 5, 2017 | 09:00 AM
blackline's Avatar
5 Year Member
If only it was that easy.
Old Oct 6, 2017 | 02:23 PM
V.8MR's Avatar
Is the oil pan and timing belt on?
Old Oct 8, 2017 | 01:47 PM
N3WBI3's Avatar
This. Spray the whole thing with wd40 and wrap it back up.
Old Oct 8, 2017 | 03:53 PM
hutch959's Avatar
for what its worth... i had one stored for over a year and this is what i did.
took off the valve cover and all the cam lobes still had assembly lube on them. so i didnt pour any oil on them.
I did pour about 2 quarts of 20w-50 in the motor and kinda poured it all along the top of the head so it would drip all over the crank.
then i took out the spark plugs and put about a table spoon of the same oil down in the cylinder.
turned over the motor a couple times, and put the valve cover and spark plugs back in it.
left it that way till i put it back in the car.
Old Oct 9, 2017 | 05:08 AM
blackline's Avatar
5 Year Member
I don't have an oil pan or head on. cylinders and crank are exposed.It is shrink wrapped.
Old Oct 10, 2017 | 12:17 PM
GTijoejoe's Avatar
Rub heavy weight oil on everything and shrink wrap it. All the surfaces and it will be like that when you unwrap it.
Old Oct 10, 2017 | 05:00 PM
hutch959's Avatar
^^Yuup
Old Oct 11, 2017 | 07:59 AM
blackline's Avatar
5 Year Member
Thanks! Like a 20-50?
TexasRS
11
Dec 29, 2004 04:30 PM
TexasRS
12
Dec 15, 2004 02:03 PM
deuxforever13
Lancer Troubleshooting
Feb 28, 2004 11:49 PM
deuxforever13
Nov 2, 2003 09:18 PM
Adolfo Rapaport
Jul 24, 2003 03:26 PM
