Shifter Bushing question, probably different than you think
Old Oct 7, 2017 | 03:11 PM
Zer0_13's Avatar
I am in the middle to swapping my wife's engine out on her 05 GSR. I am swapping over a full Evo 5 engine and trans, one thing I came to notice is, the bronze bushings I got for her shift assembly under hood, see a little off, the bushing on top, that sits horizontally fits fine. The lower one, that sits vertically, seems too tall, or more specifically, the post it sits on seems too short. I was hoping to find out: A. Is this the case? B. Does someone make a simple plug and play bushing I could use here? C. If A is yes, and B is a no, is there a way to swap out those selector arms without needing to fully disassemble the selector system?
I noticed a pin or something on the arm/shaft, and was not sure if that would make it swapable?
Thanks
Old Oct 9, 2017 | 10:49 AM
J_Striker's Avatar
I ran into this too installing an evo 4 transmission in my evo 9. My solution was to “dish†out the bushing to allow for the cotter pin to be installed. I am using torque solutions bushings. They are not Metal.
This is the best photo I I currently. Hopefully it helps you.
Attached Thumbnails Shifter Bushing question, probably different than you think-photo989.jpg
Old Oct 10, 2017 | 10:42 AM
Zer0_13's Avatar
Oh cool, im glad to see, I ended up doing pretty much exactly that just int he bronze, thank you for the reply though.
1fastvet
22
May 23, 2016 07:40 PM
Cangri X
May 10, 2012 08:37 PM
Spec-Ops1
12
May 20, 2011 09:12 AM
SoundBoy4
Sep 12, 2007 07:46 AM
