Should I block off these holes?
Old Oct 17, 2017 | 03:31 AM
TariqEvo's Avatar
What are these holes for, should I block them off or run them to connect to anything?
Old Oct 17, 2017 | 07:29 AM
I have a US EvO9, so my vacuum lines are likely different than the EvO 8
Heres our US schematic for the emission control lines. If your throttle body ports are open, they certainly need to be corrected
Old Oct 17, 2017 | 08:14 AM
barneyb's Avatar
USDM Evo 8 same lines connected the same way. Obviously these are vacuum ports that suck in unfiltered air. Just how much or what sort of porting they connect to and what effect it will have on idle if plugged - dunno.
Old Oct 17, 2017 | 09:23 AM
LetsGetThisDone's Avatar
Other market evo's (I think) don't have an EGR system, so they don't have those tubes there. I'm pretty sure those holes aren't drilled through on OP's car.
Old Oct 17, 2017 | 09:58 AM
barneyb's Avatar
Simple enough to tell, stick your finger over the port while the engine is running and work the throttle.
Old Oct 17, 2017 | 05:16 PM
hutch959's Avatar
i would agree with letsgethisdone
Old Oct 23, 2017 | 02:44 PM
stimsoni's Avatar
I can confirm JDM and ADM both have EGR. As mentioned put your finger on them to check if you need to block them.
Old Oct 23, 2017 | 07:51 PM
4b11slayer's Avatar
I doubt theyre are open ports.
Standing Z
Mar 7, 2010 07:10 AM
forum04pl
Mar 16, 2005 09:45 PM
forum04pl
Feb 8, 2005 12:55 PM
