Throttle position Sensor
Old Oct 18, 2017 | 09:45 AM
Frankie 17's Avatar
Question Throttle position Sensor
I have an evo8 260 04 that has blowen to tps,es in 5 months can anyone help solve ths problem.
Old Oct 18, 2017 | 10:41 AM
LakerRaider's Avatar
whats the question?
Old Oct 18, 2017 | 11:35 AM
Frankie 17's Avatar
Originally Posted by LakerRaider
whats the question?
What might be causing them to blow the code is sayig tps out of range
Old Oct 18, 2017 | 12:36 PM
maybe it just needs to be adjusted? do you have evoscan so you can log it and adjust accordingly?
Old Oct 18, 2017 | 02:11 PM
Frankie 17's Avatar
no m8 i hav,nt its going to auto spark on friday if its not that do you no of any other things that would do this like water
Old Oct 18, 2017 | 05:28 PM
4b11slayer's Avatar
Probably isnt properly adjusted.
Old Oct 22, 2017 | 07:21 PM
Pinknuts's Avatar
I 2nd that, just need to verify position and adjust it within range
Old Oct 23, 2017 | 03:30 PM
4b11slayer's Avatar
It needs to be at 14.5 volts fully closed
Old Oct 23, 2017 | 04:59 PM
RightSaid fred's Avatar
No it's not.
It's operating range is between 0 and 5 volts.
Need to take a measurement with a meter and see what you get.
Old Oct 23, 2017 | 07:48 PM
4b11slayer's Avatar
Originally Posted by RightSaid fred
No it's not.
My bad. 14.5 percent
Old Oct 25, 2017 | 10:48 AM
BrownParticles's Avatar
Could you go into more detail on how?
Old Oct 25, 2017 | 11:51 AM
4b11slayer's Avatar
Loosen tps bolts. Connect evoscan. Watch current data. 14.5 percent closed throttle
Old Oct 25, 2017 | 02:29 PM
yup!
anthonyrb98
14
May 29, 2012 07:19 AM
DOUGLAS
Feb 16, 2009 05:35 PM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
17
Oct 12, 2007 07:43 PM
3volution8
May 24, 2007 04:59 AM
LoCo4
Mar 5, 2006 07:03 PM
