MR Turbo
Old Apr 6, 2004 | 10:46 PM
value's Avatar
Other differences with the MR include a metal blowoff valve and a higher flowing and slightly lighter cat.
Old Apr 6, 2004 | 11:41 PM
RENN-ART's Avatar
AMS has 3 versions to their kit planned.. and the lowest model might be the perfect setup for someone looking for near stock spool with a very nice bump in hp!
the #'s i'm giving for their kits aren't 100% correct.. and AMS will probably correct my #'s.. but it's fairly close to reality..
in order of hp capability (lowest to highest):
- GT32 (appx only 200rpms slower spool than stock!.. 450whp capability)
- GT30R.. or eq. to hks3037 (appx 400rpms slower than stock.. 500-550whp capable) ->>> this will be the best choice for anyone not planning on running higher than 25psi.. since it will do about the same hp as the GT35R at that psi!!
- GT35R (appx 600rpms slower than stock.. 650whp) -> for the really power hungry folks planning on running more than 25psi..
Old Apr 6, 2004 | 11:44 PM
mitsuorder's Avatar
would be cool if someone could source out the MR bov's....
Old Apr 6, 2004 | 11:45 PM
evo542's Avatar
just get a g-reddy type-s or any aftermarket bov
Old Apr 7, 2004 | 12:17 AM
mitsuorder's Avatar
I already have a Tomei on it's way, just saying that it would be a cool if this one was an option for those in the market for one.
Old Apr 7, 2004 | 12:56 AM
chuntington101's Avatar
There are many people here in the UK that are running stock turbos (with mods) and are running around 400 bhp and similar torque. one guy had 420lbs ft at 2.3 bar off a stock unit!!!!!
Ps i will try and get some more info.
Old Apr 7, 2004 | 01:05 AM
mitsuorder's Avatar
damn, 2.3 bar from stock turbo, that's gotta be unsafe, at least with our US spec turbo.
Old Apr 7, 2004 | 03:59 AM
As I said I’m not 100% sure what they where running but I think it was just a ball bearing conversion on the stock turbo. If you can use one of the Ti ones then spool up would be around 500rpm earlier then with the alloy ones I would think. With the new bearing they are stronger anyway. I think it only costs 500 quid over here so for a turbo capable of around 2.0 bar (that is only in the mid range obviously) it’s a real bargain.
Old Apr 7, 2004 | 05:11 AM
gunzo's Avatar
cool picture .. OPTION mag ??
you forgot to mention dual solenoid boost controller and lightened doors ..
I'll go see it in detail later to see if there's anything else
Old Apr 7, 2004 | 06:16 AM
Hooptie157's Avatar
Awesome info guys keep it coming!!
BTW when is the AMS GT30R kit coming to market? (I gotta start saving )
Old Apr 8, 2004 | 02:40 AM
Just got a PM from one guy that builds the ball bearing units over here. He says that he uses new units with totally new cores with the new bearings in. I think it will be standard size on both sides and you just chose the stock turbo that you want. He also said that he doesn’t like to use old units (suppose there are less guaranties for longevity). No mention of cost though. It really is a good idea if you are looking for around 400bhp though. There was a guy with nearly 400 (restrictive exhaust) with only the basic mods (intake, exhaust, FMIC etc). Hope someone over there picks up on this as a cheaper and often more effective solution to a bigger turbo.
Thanks Chris.
Ps not sure on the AMS kit but hope its soon.
Old Apr 8, 2004 | 07:21 AM
eclipsegs2k1's Avatar
how do you get in contact with this guy? thanks for the info chuntington, it's very helpful
Old Apr 8, 2004 | 07:31 AM
mifesto's Avatar
Ti turbo the way to go!
Old Apr 8, 2004 | 08:24 AM
Hooptie157's Avatar
Whats the max HP the TI turbo can pump out and is it a direct bolt on to our cars?
Old Apr 8, 2004 | 08:41 AM
mifesto's Avatar
the Ti turbos on the JDM spec evo doesnt pump significantly more power but it definetly spools faster
