Double pumper!
just to be clear... at idle you should see 43 on the rail.
on boost you should see 43 plus whatever you are boosting.
(for simple math)
if you have 40 psi of fuel pressure at idle, and you boost 40 psi, then you should have 40+40 = 80 fuel pressure when at 40 psi boost.
if your fuel pumps cant keep up, you will see less then the 80 on the rail.
when i had fueling issues, running 40 psi boost, i was seeing around 75 psi on the rail.
(for simple math)
What do you think my turbo is capable of pushing with the supporting mods Gt35r ballbearing. I’ve seen 680 hp on virtual dyno with duty cycle at 100% and at 38psi! Is that what I should push for to stay around 38psi I’d boost and 680hp/520torque?
(for simple math)
(for simple math)
STIbyebye
Apr 28, 2016 05:12 PM
evovin
Apr 19, 2008 11:05 PM
Nesiop
Aug 4, 2007 08:44 AM
David Buschur
22
Feb 1, 2007 12:23 PM
