Injector Dynamics ID1050x vs 1000
Im not sure if the ID's are plug and play but one way to find out. Essentially remove the old injector clips, there is a metal clip that needs to be removed then it'll come right off. Then either that plug will fit right onto the new injector or you will need to get some pigtails and solder then onto the old injector wires or purchase some plug and play adapters.
FIC 1200s and 1650s have the same plug as the factory Evo 8 and 9 so no wiring is required
nisils14
Nov 28, 2017 12:58 PM
