Possible valve cover leak, any insight?
Old Dec 30, 2017 | 07:39 PM
OneSlowEvo8's Avatar
I am seeing a small amount of oil on my manifold, seemed to be dripping out of one of valve cover bolts.
It isn’t enough oil to be seen on ground, doesn’t smell like it’s burning oil and the dip stick reads perfect oil level. I’ve been seeing this for a few months now. I will post up some pics. Thanks!
Old Dec 30, 2017 | 08:43 PM
babaz7's Avatar
i had a similar issue, the mechanic over tightened the valve cover bolt causing the cover to crack, oil would seep onto the manifold and eventually downwards, i tried to fix it with adhesive and filling but it didnt work for me, so in the end had to buy a new valve cover.
try finding where the leak is coming from and repair it with a bond and see if that helps. for me it didnt.
Old Dec 31, 2017 | 11:32 AM
barneyb's Avatar
Could be its time for another gasket.
Old Dec 31, 2017 | 05:34 PM
hutch959's Avatar
Order a new gasket set.
take off the valve cover. Inspect it closely. If its cracked, put it back on with the old gasket and find a valve cover that is not cracked.
put non-cracked valve cover on with the new gasket set. follow the directions in the service manual, add the gasket maker where it says to add it, and just snug the bolts down.
leak fixed.
chaz517
Oct 29, 2007 07:01 AM
Blacksheepdj
Lancer Troubleshooting
Mar 31, 2005 08:44 AM
w8tless1
Aug 4, 2004 09:32 PM
Mattsteg45
Jan 28, 2004 08:49 PM
