What size injectors?
Old Jan 11, 2018 | 02:54 AM
Willpegley's Avatar
Right so I won’t be running e85 as in the uk it’s hard to come by and expensive so I’m going to run 100 octane gas and a meth kit supplied by DevilsOwn and 100% meth as recommended by them which will give me around 108 octane from that!
I know high hp applications with e85 need big fueling equipment, I’ve already got a twin 450 br double pumper and Perrin fuel rail but which size injectors would you guys go with for that? 2000’s or could I get away with less? My car is going to be a high hp car so I want to make sure it’s going to be enough
Old Jan 11, 2018 | 07:44 AM
LetsGetThisDone's Avatar
Define high HP. Like, turbo size..?
2000's will make a touch over 1k on gas. Your meth is basically adding additional fuel to the equation also, so the size injectors you run for that will also change how big you need your primaries to be. Like a set of 1650 primaries can make about 750 on gas then add however much meth you're spraying.
Old Jan 11, 2018 | 09:38 AM
Willpegley's Avatar
Had plans for my car to be around the 900 mark, my turbo is a gt42r (76mm)
Old Jan 15, 2018 | 04:06 PM
Dakota Evo's Avatar
high quality 2000cc injectors such as ID2000 and FIC2150
will drive nicer than cheap low z pte1000 fic1000
stay away from low z fic 1450 crap injectors
If you are going to run oxyginated fuels run fic 1650 high z or ID1700 if not just go straight to 2000cc the 2000cc are cheaper btw
Old Jan 24, 2018 | 10:17 AM
Aristocrat Dave's Avatar
To be safe (and do things right), I recommend ID2000s. You may also want to go with a dual fuel rail setup.
I am a vendor for Injector Dynamics if you need a set!
Old Jan 24, 2018 | 04:25 PM
STM Tuned's Avatar
Get a set of 2000's or 2150's and call it a day, if you want to turn it up in the future you will still have room to grow.
We trapped 182mph on a single set of 2150's on pump E85
-Austin@STM
Old Jan 24, 2018 | 04:48 PM
hutch959's Avatar
^^^2150
Old Jan 25, 2018 | 09:22 AM
blackline's Avatar
5 Year Member
ID2000 or FIC2150's.
Old Jan 25, 2018 | 09:26 AM
e_kobz's Avatar
I feel like people see the name ID2000 and assume its a 2000cc injector. The ID2000 actually flows 2225cc's....
mexicanevo
West Region
Apr 26, 2007 02:05 PM
imajinmyfx
Aug 22, 2005 02:07 PM
justchil
Jul 18, 2004 08:33 PM
ChaseEVO
24
Oct 20, 2003 12:30 PM
