Balance shaft timing
Old Feb 4, 2018 | 11:22 AM
SDevol8's Avatar
Hello I am replacing te toming and balance shaft belts on my car and am following the boostedfilms video. I tried to set my balance shaft the same way the did and also am off about 2 teeth eveytime I put tension on the tining tensioner. Everything is in time until I put tension
Old Feb 5, 2018 | 03:52 PM
SDevol8's Avatar
Bump
Old Feb 5, 2018 | 06:27 PM
kaj's Avatar
kaj
If you are having trouble following a how-to, I'd suggest having someone do it for you. It's a pretty straight-forward process... Not sure what else we could tell ya, based on your post.
Old Feb 6, 2018 | 07:02 PM
Project_Broke's Avatar
I’m assuming you’re talking about the front shaft, as the rear one should be pretty self explanatory.
The service manual is a great help here.
Make sure you have all the excess belt play on the tensioner side beforehand, get it as tight as possible on the oil pump (front balance shaft) and crank. Also, line up the crank and oil pump, and exhaust cam one tooth counterclockwise, when you tension the belt, they will be tdc.
boostawd16
Nov 20, 2013 04:47 AM
STIKiller4G63
10
Oct 2, 2012 07:44 AM
Blue91lx
May 16, 2012 08:35 AM
Anarchy99
11
Mar 7, 2012 12:17 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
