Intake manifold question
Old Feb 12, 2018 | 07:01 AM
blackline's Avatar
5 Year Member
Does anyone know where this(circled in red) port connect to?
I pulled the engine from the car a few months back and due to bad labeling I don't know where it connects to.
Old Feb 12, 2018 | 08:17 AM
DontStopMe's Avatar
I think PCV hose to valve cover if memory serves me correct.
Old Feb 12, 2018 | 08:27 AM
heel2toe's Avatar
Yep, thats where the PCV from the back of the valve cover connects
Old Feb 12, 2018 | 08:38 AM
blackline's Avatar
5 Year Member
Thanks!
Thanks!
Since I'm not using the PCV and going to a catch can, can use that port for a vacuum block?
Old Feb 12, 2018 | 08:52 AM
heel2toe's Avatar
You could technically use that as a vacuum source however even if you dont use a PCV depending on your CC setup you still could possibly use that nipple regardless. The difference would be simply that the CC is in line vs just a straight hose to that nipple.
If you plan to have a VTA CC then most people just cap off that nipple so in your case you could instead use that as a vacuum source.
Old Feb 12, 2018 | 08:53 AM
blackline's Avatar
5 Year Member
Cool, thanks!
evo8vz
Dec 16, 2016 08:27 AM
LGshow19
41
Feb 22, 2011 02:29 PM
apeximprt2nr
Sep 22, 2008 06:22 AM
Nomad4g63
12
May 9, 2008 07:32 AM
EvoIXMR
11
Mar 18, 2008 07:31 PM
