Drivable clutch for 475-500 WHP
I have an Evo 8, FP red otw and after tuning I should be mid to high 400's in HP. Currently still have the stock clutch (not slipping). I don't launch and have no intentions of launching. What is the best clutch out there that can handle that power and is close to stock feel?
Thanks!
Thanks!
It really depends on what turbo he goes for and the torque the car will be making.
Exedy twin is nice, the SD pedal feel is almost like stock. Although it comes with a price tag.
There are affordable single disc options that can hold 350-375 WTQ that won't break the bank and are perfectly driveable.
Exedy twin and tripple are loud for daily drivers. I have run both and you can't press your clutch in to rev your engine without it sounding like there is something terrible off with the car. I understand that it's normal, but I need to find a clutch that holds 600ftlbs torque that's less noisy.
That being said, nothing beats the feel of this clutch. It just doesn't slip.
I suggest running a single of some type.... act
I have had 2 twins, hd & sd pressure plates.
They dont like being stuck in traffic situations in a hilly area. The thin steel plate warps quickly for me p/n PP02. Once this warps, it becomes difficult to get into gear when idling cold. the clutch just draps a bit, despite chasing the release point with the adj. rod.
I will be pulling my current twin soon.
ACT HDSS. I Have 340 torque and my last act 6 puck one lasted over 60k miles(with a nice chunk of launches, a lot of slipping my end which probably could've gotten a lot more miles out of the clutch if I didn't suck at it).
I learned that for DDing a single street disk is best. For drag and track, you can't beat a twin or triple.
I would also agree on a ME2-HDSS for a stock engine or a ME2-HDG6 6 puck if you are going to turn it up down the road. Sprung disk for a street car.
The HDSS is a single disk full face and will drive well.
The ME2-HDG6 is a 6 puck and with proper break in and driving works well for a street clutch. I'm on my third replacement disk with a taller final drive its a nice clutch for an occasional launch and it shifts well.
Thanks as always Aby for the real scoop.
Related questions to all:
1. What grease do you recommend for the splines / pivots in the tranny? Seems the urea based stuff from Honda is highly recommended. I have and was planning to use Bendix BL20.
2. What’s the best tranny fluid for those who do get after it? I’ve tried a couple, liked the Mitsubishi 6-speed stuff by far the best for shifting, but TRE recommends Motul, which I’m using. Shifting definitely got worse. I’m also visually noticing wear on 4th gear though, so it’s a trade.
Installing a new HDSS next week.
