Broken Balance Shaft Belt
Old Feb 17, 2018 | 04:28 PM
  #76
drive955i's Avatar
^ Or a decently weighted flywheel, for that matter.
Always forgetting something...
Old Feb 17, 2018 | 04:36 PM
  #77
2006EvoIXer's Avatar
Agree 100%.
This is to reduce engine movement from launches and shifts.
It will twist the engine/tranny/TC by preventing movement at the timing belt end. The drive shafts and center shaft should be able to pivot to deal with this, but I don't see the value of trading one motion for another.
I only can think of downpipe being happy since it won't pivot as much where it joins with O2 housing.
Originally Posted by drive955i
[QUOTE
Seems a shock absorber like that would be used to quell exterior engine vibrations that balance shafts and vibration dampers attempt to quell on the engine’s interior. Don’t get me wrong, I understand the reason for installing it, but I wouldn’t call it an adequate replacement for a quality damper or balance shafts.[/QUOTE]
Old Feb 17, 2018 | 04:54 PM
  #78
BluEVOIX's Avatar
Originally Posted by 2006EvoIXer
At 7000 rpm, your speed is 60mph. Going back to 1st gear, it's just under 10,500 rpm if your clutch was fully engaged.
When your Sentra had vibrations at 3500 rpm, was it worse at 7,000?
From what I remember back in 2004 ,vibrations felt after bs removal where only around the 3500-4500 rpms range . I don't remember having any vibrations before or after that. I did notice a much quicker revving moter in neutral .
Also , the Sentra SER Spec V using the QR25DE motor did not rev that high. If I remember correctly the redline/rev limiter was 6200 rpms . It was a 2.5L motor also used in the Altima .
I did notice improvement in MPG's . I went from best of 210-220 miles per 10 gallons to 240-260 miles depending on how I drove . Unfortunately , after removing the bs a few months later i had a argument with a tree and the tree won.
Old Feb 17, 2018 | 04:56 PM
  #79
LetsGetThisDone's Avatar
Originally Posted by barneyb
Since there's much speculation as to the cause of the secondary vibration that balance shafts were invented to correct, here's the explanation. Its a geometry problem.
When a crank moves 90 degrees from the top dead centre (TDC) in a single cylinder engine positioned upright, the bigend up-down position is exactly at the half-way point in the stroke, but the conrod is at the most tilted position at this time, and this tilt angle makes the small-end position to be lower than the half-way point in its stroke.
Because the small-end position is lower than the half-way point of the stroke at 90 degrees and at 270 degrees after TDC, the piston moves less distance when the crank rotates from 90 degrees to 270 degrees after TDC than during the crank rotation from 90 degrees before TDC to 90 degrees after TDC. In other words, a piston must travel a longer distance in its reciprocal movement on the top half of the crank rotation than on the bottom half.
Assuming the crank rotational speed to be constant, this means the reciprocating movement of a piston is faster on the top half than on the bottom half of the crank rotation. Consequently, the inertia force created by the mass of a piston (in its acceleration and deceleration) is stronger in the top half of crank rotation than on the bottom half.
So, an ordinary inline 4 cylinder engine with 180 degrees up-down-down-up crank throws may look like cancelling the upward inertia created by the #1-#4 piston pair with the downward inertia of the #2-#3 pair and vice versa, but in fact the upward inertia is always stronger, and the vibration caused by this imbalance is traditionally called the Secondary Vibration. - Wikipedia
I posted half of that on like the first page lol
Old Feb 17, 2018 | 05:05 PM
  #80
Glad you're okay!
From reading, some claim there's about a 15 hp loss from balance shafts.
Old Feb 17, 2018 | 05:12 PM
  #81
Do you know the position of the weight when timing mark is set up? I think the front BS has weight down. Is it also down to cancel out the left and right motion so the only motion it induces it up from both BS at same time, which counters the power stroke pushing down for TDC to 90 degrees? This would make sense.
Old Feb 17, 2018 | 05:18 PM
  #82
If this is the case, I (personally) will always keep both my BS because the timing is set to counter the power stroke on every cylinder. There isn't anything else that is timed this closely. If I plan to brace the engine directly to car frame and prevent any engine movement, then I will get rid of BS since the braces will do the same thing. But car vibrations will be nuts
Old Feb 17, 2018 | 05:31 PM
  #83
Ayoustin's Avatar
I have a good amount of experience developing balance shaft systems for OEMs. I've literally reviewed hundreds of hours of run data on engines, talked about this same stuff with other engineers who design these systems for a living, seen results first hand. Removing balance shafts will cause no damage to an engine. They are only for NVH purposes.
There are TONS of 4 cylinder engines that don't use balance shaft systems and you don't hear of them chewing through bearings because they vibrate so badly. And if you think that a 4 cylinder engine without balance shafts has a lot of vibrations, you should see the kind of vibrations an odd firing V10 has. I've talked to engineers who've had viper engines rip motor mounts out of the walls they were mounted to because they were vibrating so badly.
Old Feb 17, 2018 | 05:35 PM
  #84
BluEVOIX's Avatar
Glad you're okay!
I was fine, Sentra and the tree were not . Unfortunately I never dynoed or went to track after the BS removal to say how much powers it may have "freed" .
Check out this video I found if a DSM dynoing before and after BS removal . Also lightened flywheel.
Old Feb 17, 2018 | 05:45 PM
  #85
BluEVOIX's Avatar
Here is a good video explaining balance shafts in general for inline 4 motors.
Old Feb 17, 2018 | 05:59 PM
  #86
Thanks for chiming in!
So the only stress from removing BS goes to the engine and tranny mounts?
Old Feb 17, 2018 | 06:41 PM
  #87
This was exactly what I was imagining. Thanks for the link.
https://m.youtube.com/watch?v=hwigSbyQ7AI
Old Feb 18, 2018 | 07:01 AM
  #88
drive955i's Avatar
Makes perfect sense to my feeble mind!
So I’ve heard, the larger the displacement of the I4 engine (longer stroke) the worse the second order vibration, as the pistons have to achieve higher speeds at any given rpm. So the balance shafts may be something worth keeping when expanding stroke.
Old Feb 18, 2018 | 08:10 AM
  #89
DontStopMe's Avatar
These things? These things will cause engine, tranny, and transfer case to twist more. I'm not sold that this is good to use.
Agreed. I know a few evo owners who bought this and then got rid of it not long after.
Old Feb 18, 2018 | 09:41 AM
  #90
captiveis1's Avatar
I am so glad someone brought EE into this discussion. I was about to link that video before I saw you had beat me to it
