Dented intercooler - repairable?
Old Feb 20, 2018 | 03:09 AM
inin36's Avatar
The bottom part of the greddy intercooler is slightly dented (1 row) due to towing. Its negligible for some but that slight dent is an eyesore for car enthusiasts like us. Is isit possible to pull or knock back to its original state?
Old Feb 20, 2018 | 06:41 AM
Evo8cy's Avatar
Yes it is possible, depending where exactly and how much it has been dented, you can use the appropriate method.
If it's a minor dent of the last row along with the plate , you can carefully straighten it by using a screwdriver and small pointy pliers.
If it's a bigger one , deeper bent concerning two last rows or so, then you need to weld a piece of aluminum on the bottom plate and pull it until it straightens. Again use pliers and screwdriver.
If it's a pretty major bent then you need to cut the bottom plate where it is dented ,straighten the rows and fins with a screwdriver and small pointy pliers ,then straighten the plate and weld it back.
Marios
Old Feb 20, 2018 | 06:05 PM
inin36's Avatar
Marios
Thanks for the advise. Mine is only dented the last row at the bottom. What it affect the filter or performance?
Old Feb 21, 2018 | 02:01 PM
Evo8cy's Avatar
It won't have any effect in performance.
Marios
Old Feb 21, 2018 | 06:55 PM
inin36's Avatar
Marios
thanks man. will try it out
Old Feb 23, 2018 | 03:25 AM
lilbro23's Avatar
Weld it
the_evodude
Dec 17, 2012 12:04 PM
Evo8nut
May 11, 2007 05:59 AM
GNV Motorsports
Aug 18, 2006 09:38 AM
mtnracer
May 3, 2005 10:44 AM
