low compression
Old Mar 6, 2018 | 02:02 PM
  #31
RightSaid fred's Avatar
Originally Posted by deylag
If there are any vacuum leaks on the intake manifold then that would cause less air to go into the cylinder when you crank.
Your statement makes no sense at all.
Originally Posted by 2006EvoIXer
Check intake cam lobes for cylinder 2 to make sure it is making full contact with rocker arms. If it does make tight contact, try to compress HLA under those two rocker arms. If they compress, HLA is probably leaking and not holding rocker arms fully up and allowing valvesprings to not fully open. This can also be the source of your lifter ticks.
It's not going to affect compression, if anything it'll go up due to the intake valve closing sooner
Originally Posted by nor11384
Well, got a compression tester from autozone and all cylinders showed 153 except that one which showed 90 - 100. Poured a cup of oil and and it jumped to 120. :sigh:?
That test says it's a broken piston.
Old Mar 6, 2018 | 02:12 PM
  #32
2006EvoIXer's Avatar
You're right. A bad lifter will slam the valves shut. He better start saving up.
Has your buddy removed his cams recently and reinstalled without bleeding the lifters?
Old Mar 6, 2018 | 03:07 PM
  #33
nor11384's Avatar
FCOTM Winner
Not that I know of but always had bad lifter tick...
Old Mar 6, 2018 | 03:19 PM
  #34
then it's likely not the lifters.
Old Mar 6, 2018 | 03:40 PM
  #35
nor11384's Avatar
FCOTM Winner
Why? Never took a compression test...could have been like this for a while...
Old Mar 6, 2018 | 03:43 PM
  #36
Or multiple problems with multiple bad mods.
Old Mar 6, 2018 | 03:58 PM
  #37
only way I can think of caused by lifters is if someon swaps out cams and didn't bleed the lifters. As they reinstall the cams they could compress some accidentally when installing new cams. Then lifters would rest high and under pressure, holding valves open.
Old Mar 6, 2018 | 04:15 PM
  #38
nor11384's Avatar
FCOTM Winner
Well, lets see...i plan on pulling the head and see if i can see anything...may have machine shop test it and see if valves were closing as they should...maybe it was carbon build up or something?
Old Mar 6, 2018 | 04:33 PM
  #39
use an othoscope and look inside through spark plug hole. They're so cheap and I think it's about $30 on Amazon.
Old Mar 6, 2018 | 04:44 PM
  #40
nor11384's Avatar
FCOTM Winner
Yeah i could try that and see if something sticks out...
Old Mar 6, 2018 | 04:50 PM
  #41
that's the easieat thing to do. Also check cylinder 2 walls for signs of wear. I can see cross-hatches when I last looked in my cylinders.
Old Mar 7, 2018 | 04:39 AM
  #42
nor11384's Avatar
FCOTM Winner
Yeah I have a buddy that has one. Going to try that and see. Well he actually has one of those cheap wires from wish that you hook up to your phone but that’ll work. I think you can take screenshots so if I can do that I’ll post pics here.
LancerShop.com
Lancer Vendor Classifieds
Oct 27, 2016 06:25 PM
dambikeracer
57
Mar 14, 2010 07:43 PM
speedfreak24
Feb 15, 2010 08:35 PM
Show Off
Feb 25, 2008 10:52 AM
Hotshot940
Lancer Aftermarket Forced Induction Tech
13
Mar 30, 2004 08:19 PM
