htuff rods
Old Mar 11, 2018 | 11:55 PM
zuppy's Avatar
Recently made 717/508 with the Manley H-Beam rods, seems to be holding great so far; I have the ARP 2000 studs for both the head and rods too.
Old Mar 12, 2018 | 08:02 PM
inin36's Avatar
nice. how many miles now?
Old Mar 15, 2018 | 09:25 PM
zuppy's Avatar
A little under 5000. Actually my rings are worn now so I'm doing a rebuild in the next few weeks and will be upgrading to Ibeams; just want to be on the safe side incase they actually do snap/bend.
Old Mar 16, 2018 | 12:45 PM
Pal215's Avatar
I'm wondering now how these "turbo tuff" H beams compare to the "turbo tuff" i-beams in terms of absolute strength.
Old Mar 19, 2018 | 12:40 AM
inin36's Avatar
let us know hows the rod holds after 5000 during your rebuild.
given the price and and studs, i would like to know too.
Old Mar 19, 2018 | 04:29 PM
ExViTermini's Avatar
I beam will always be stronger
Old Mar 19, 2018 | 05:23 PM
2006EvoIXer's Avatar
Yes. Stronger to withstand vertical compression forces from pistons, but weaker to resist lateral tension from its own mass at high RPMs. I wonder if there is a high enough RPM where the I beam will start vibrating (like a tuning fork). Yes, I wonder on the weirdest things!
Old Mar 19, 2018 | 06:51 PM
inin36's Avatar
i was on i beams before the bearings gave way. able to hold alot of abuse and it was pushing 700hp. There are alot of reviews for ibeams and hbeams but not the htuff.
Old Mar 19, 2018 | 07:07 PM
how high were you revving? And which bearings were you using?
Old Mar 19, 2018 | 07:08 PM
RS200's Avatar
Jackson Auto Machine was recommending these before, they know their way around a 4G63. It's going to be somewhere between the budget rod and the I-beam. I'd guess safe to 700ish whp? For the extra $44 over the budget rod, might as well. ExtremePSI sells them for $399.
Old Mar 19, 2018 | 08:43 PM
inin36's Avatar
9k. acl bearings. was on motul xcess iirc when it gave way
can share link for the recommendation?
Old Mar 19, 2018 | 08:48 PM
Do you think the rod weight wore a bearing out at 9k?
Old Mar 19, 2018 | 08:52 PM
inin36's Avatar
possible. but i reckon its the oil. because i usually used motul 300v and it was detuned to 600hp at the point when it broke.
Old Mar 19, 2018 | 08:58 PM
Do you have pictures of broken bearings and close up of the wear areas?
Old Mar 19, 2018 | 09:31 PM
inin36's Avatar
i didnt take any photos but the bearings and crankshaft gone, block scratched, rod and piston ok.
