Synchro
Old Mar 3, 2018 | 03:46 PM
Kyawzaw's Avatar
Synchro
I have a problem with synchro at 1st gear high RPM
Need to change synchro? Or can i still use?
What's the problem if i not change synchro?
Old Mar 3, 2018 | 09:24 PM
2006EvoIXer's Avatar
How do you know it is the synchro? Are you down shifting into 1st often?
Old Mar 4, 2018 | 06:31 AM
drive955i's Avatar
Does 1st gear even have a synchronizer? I know, generally speaking, the European manufacturers like to use a 1st gear synchro and the Asians do not. They expect you to only use 1st gear from a standstill, hence no need for the synchro.
Old Mar 4, 2018 | 11:08 PM
Double post
Old Mar 4, 2018 | 11:09 PM
I believe 1 & 2 are triple synchros, 3 is double synchros, 4 & 5 are single, and reverse is double synchros.
1998_GSX
Mar 7, 2013 07:46 AM
Dr. Fob
11
Oct 1, 2011 07:41 AM
intolerance
38
Dec 29, 2004 04:33 PM
mr2
Mar 30, 2004 05:37 AM
Porsche518
29
Dec 20, 2003 12:06 AM
