EVO 4-5-6 Tranny into 8/9
Old Mar 9, 2018 | 03:28 PM
Evo VIII 4o1's Avatar
Is there anything I need to be aware of when I use a 4/5/6 tranny in my 8/9 5 speed? Any issues with speed sensors or gear selector arms?
Old Mar 11, 2018 | 08:17 AM
MR ArcticC's Avatar
It works fine, I have done it to my Evo8 MR. Check the speedo sensor gear. It should be 28 tooth on 8/9 but it is probably 29-30 on those boxes.I have an Evo4 5-speed box but it was rebuild with new evo9 rs shafts and gears. I still have the 30 tooth speedo gear in the box and the speedometer reads too low. The 28 speedo sensor gear is MD747055.
And check the shifter cable ends at the box side. The bushings are probably 22mm both and seems like us model 5-speed boxes have different size bushings there (and the gear selector pins are different size).
Old Mar 12, 2018 | 06:54 AM
Thanks arctic! I will Check the gear and order accordingly. I was told the arm is a different size and they said it may be tight of the shifter. In regards to my the bushings, if I bought new US version ones, will they not work?.
Old Mar 12, 2018 | 12:32 PM
MR ArcticC's Avatar
Us model shifter cable bushing pin holes are about 8mm and 10mm and Evo4 5-speed gear selector pins are both 8mm and the cable bushings are 22mm OD and 8mm hole (both). So there is a mismatch. If you just could swap the gear selector housing from your old 5-speed box? And take the speedo gear from your old box too. And use your own 8/9 gearbox/engine mounts.
Old Mar 12, 2018 | 04:48 PM
Arctic thanks. Hopefully this helps somebody else
Dbz00
16
Sep 20, 2013 08:43 PM
MR. EVO MR
European Forum
18
Jan 11, 2012 04:37 AM
deegaw11
12
Mar 19, 2011 01:50 PM
ealt
Jul 31, 2010 10:26 AM
imalancerman
Lancer Tranny/Drivetrain Tech
Aug 21, 2007 07:59 AM
