Stock 9.8 hotside/71HTA. Which actuator?
Old Mar 18, 2018 | 09:43 PM
jordynmylz's Avatar
The Evo 9 bracket fit, but the rod of the actuator was about an inch to the right because the lever arm on Evo 9's rotate to the right not left. Maybe I could use an Evo 9 bracket with the Evo 8 actuator.
Old Mar 18, 2018 | 09:45 PM
2006EvoIXer's Avatar
It's strange how there isn't a kit made for this. You can't be the only one doing this.
Old Mar 18, 2018 | 09:58 PM
jordynmylz's Avatar
Yeah, seriously. Just talked to my buddy. He's just gonna look for a 10.5 hotside and eliminate this problem. He still has the Turbosmart Evo 9 WGA, so we could just bolt it right up and be good to go. Do you know of any sites selling a 10.5 housing? I've just been looking and the few sites I found them on were out of stock.
Old Mar 18, 2018 | 10:05 PM
I've never looked. It will be a challenge since everyone is looking for 10.5 for HTA71 (including evo 8.5 and 9s) because many are old and are starting to fail. GL on your search.
Old Mar 18, 2018 | 10:11 PM
If you find one, consider porting the exhaust impeller port closer to impeller. This is what I did (when I was done, the shelf was barely taller than impellers-blue ink was shaved down):
Old Mar 18, 2018 | 10:41 PM
jordynmylz's Avatar
The only one I could find in stock is this one from Europe...
https://www.rosssport.com/Brands/OWE...MHI49178-17020
Does that look correct?
Old Mar 19, 2018 | 06:17 AM
Here's my HTA71 before it was installed.
Old Mar 19, 2018 | 06:20 AM
Looks correct, but that's too expensive. $631 is too much for just the hotside. You're better off getting a htz green.
Old Mar 20, 2018 | 03:44 PM
Did you see this? I'm not sure if this will work for you:
https://www.evolutionm.net/forums/sa...oem-parts.html
V.8MR
Oct 1, 2017 09:40 AM
Evo VIII 4o1
Mar 3, 2015 06:22 PM
getsideways
Aug 19, 2011 07:01 PM
EE
11
Jun 16, 2008 08:16 PM
