Dirty intake manifold? Evo 8
Old Mar 28, 2018 | 10:53 AM
cameronmahbay's Avatar
5 Year Member
what’s up everyone? So picked up my evo a few weeks ago and I have been slowly going through it. I looked down the intake manifold and it’s got a lot of carbon build up. Is this normal? I was thinking about pulling it off but it seems like a real pain. I have the injectors off right now so I can send them in for service. I tried looking through the forums for the best cleaning but didn’t really come up with much. Thanks!
Old Mar 28, 2018 | 10:58 AM
Pal215's Avatar
That looks like a pretty bad case, but I have seen it happen. The oem setup forces the intake manifold to vacuum crank case fumes, which could cause extra build up. On top of that, you have the EGR system spewing exhaust fumes into the mani. I would use a can or 2 of brake cleaner on the inside of the manifold before installing it. It can be cleaned and restored.
Old Mar 28, 2018 | 10:59 AM
5 Year Member
so best just to take it off? Damn lol
Old Mar 28, 2018 | 11:01 AM
Pal215's Avatar
Yup, it's a pita, but well worth the time as you don't have to worry about all that caked on sludge going into your combustion chamber. It's nasty and chewy stuff for the engine that if broken loose could cause knock.
Old Mar 28, 2018 | 11:03 AM
5 Year Member
gotchya! Thanks 👍🏼
Old Mar 28, 2018 | 11:47 AM
six40's Avatar
Remove it and clean it properly. Same with the throttle body. Then do an EGR delete, and run a catch can. Problem solved and prevented from happening again in the future
Old Mar 28, 2018 | 12:02 PM
2006EvoIXer's Avatar
The lazy way is to Seafoam the crap out of it.
But do it the right way: take it off, clean it out, and replace the gaskets. It is a lot of work and while you're at it, replace all the tubing behind and under the manifold.
lonestarevo83
Jul 31, 2011 10:10 AM
Darkn3s
Mar 25, 2010 06:53 AM
EvoVIII_MR2005
Mar 23, 2006 07:22 PM
