Evo8 with fp54
Old Apr 17, 2018 | 06:44 AM
e_kobz's Avatar
The FP54 is not the new green. The FP54 is a limited run upgrade to the green with the MHI housing. It was introduced in the beginning of 2016. FP only made a handful of these as there are no more MHI housings. Just for clarification the SS green is not a FP54
Old Apr 17, 2018 | 06:47 AM
2006EvoIXer's Avatar
My Error
Old Apr 17, 2018 | 06:50 AM
Evo8cy's Avatar
http://www.forcedperformance.net/PRO...4GreenHTZ.html
Marios
Old Apr 17, 2018 | 06:51 AM
that explains everything!
Old Apr 17, 2018 | 06:52 AM
e_kobz's Avatar
Old Apr 17, 2018 | 06:56 AM
Evo9isLife's Avatar
5 Year Member
Originally Posted by 2006EvoIXer
Are you sure you have a Green and not something bigger?
Unless I'm mistaken, it looks like the dyno pulls are starting at about 3.5k rpm instead of the usual 2 - 2.5k rpm. Could explain why it looks laggy for a green.
Too bad they're not selling these any more.
Originally Posted by Evo8cy
Old Apr 17, 2018 | 06:59 AM
Good catch!
Old Apr 17, 2018 | 07:18 AM
e_kobz's Avatar
if you have a usable MHI housing I’m sure FP can build you one
Old Apr 17, 2018 | 07:40 AM
Evo8cy's Avatar
https://www.ebay.co.uk/itm/Mitsubishi-EVO4-9-TD06SL2R-Turbo-Turbine-Wheel-Turbine-Houisng/122697525952?epid=1642859153&hash=item1c9157aac0:g :6DsAAOSwLUpaUy5r
The above is also an 11.5cm2 housing instead of the standard 10,5cm2 one, which will allow for a bit more top end flow, without any actual sacrifice in spool time nor a raised full boost rpm point.
Couple this with :
https://www.ebay.co.uk/itm/Kinugawa-Turbo-Compressor-Housing-Fits-4G63T-MHI-EVO-9-20G-w-GTX-Billet-Wheel/253426273029?_trkparms=ao%3D1%26asc%3D201709121018 45%26meid%3Dc6a90bbdcca44ba7a95b77e25bec3122%26pid %3D100705%26rk%3D1%26rkt%3D1%26%26itm%3D2534262730 29&_trksid=p2045573.c100705.m4780
You can use your own existing chra.
Marios
Old Apr 17, 2018 | 07:47 AM
This turbo still seems abnormally higher flow than 57 lbs/min. If I was to guess, I'd say it's 64 or 65 lbs/min.
Old Apr 17, 2018 | 07:52 AM
Does Dyno Dynamics dyno have a correction factor?
Old Apr 17, 2018 | 07:58 AM
Evo8cy's Avatar
No it is around there between 57-58 max lbs/m on a high V.E and thermal efficiency setup, in order to push the turbo to its max cfm output and also be able to take in and make use of that cfm flow. Of course one needs to use quality fuel in order to make max use of the specific cfm, the better the fuel ( calorific value and detonation resistance) the more power the setup will make.
So the o.p here could have made 550 whp + on e85 on this, on the same dyno.
Marios
Old Apr 17, 2018 | 08:51 AM
A quick conservative calculation I was shown uses lbs/min × compression ratio to get whp. There's a local evo with built engine 10.5CR and FP Black. On E85, it put down 741 hp at RRE and turbo wouldn't boost more than 41 psi.
71 lbs/min × 10.5CR = 745 hp
in this case, 57 lbs/min × 8.8CR = 502 whp (which is about what OP has on 93!). I want to see what OP gets on E85!
Old Apr 17, 2018 | 09:05 AM
boost556's Avatar
That is about 500whp on dynojet on 93. That's more than what I'm making on E85! You have a monster setup. Are you sure you have a Green and not something bigger?
Good catch!
i had the 71 hta on my previous evo and didn'
Even know abt the fp54 until I bought my new car. So yeah didn' know they stop making them. I hope they rebuild them though lol .
